Are Expensive Brake Fluids Worth the Extra Cost?
Old Jul 29, 2024 | 12:49 PM
Default Are Expensive Brake Fluids Worth the Extra Cost?
Let’s be clear up front—if your brake fluid has not been changed in over a year, you are past due to replace it. Brake fluid is hygroscopic—it naturally absorbs water from humidity present in the air. Therefore, it requires regular maintenance.
This article is meant to help you make an informed choice when buying brake fluid at the parts store.
A lot of technical innovations in automotive chemicals have been linked to better performance, increased engine or component life or a less toxic, more earth-friendly disposal for spent fluids. Brake fluid—the hydraulic liquid that is used to “push” your brakes when pressure is applied—has similarly gone through evolutionary development.
Very much like engine oil or power steering fluid, there are dozens of brake fluid choices at your local parts store. They carry everything from the store brand DOT 3 fluid costing a buck, to very high-end synthetic fluids that may cost twenty dollars per can. Keep in mind, the same rules that apply to selecting engine oil apply to brake fluid: the more expensive option is not always the best option.
Some of the brake fluids available for racing applications might perform well when used in those conditions but might not be right for the street.
So, what is the difference between DOT 3, DOT 4, DOT 5, and most recently DOT 5.1?
The US Department of Transportation (that’s what the DOT stands for) established specifications defining a number of PROPERTIES to which brake fluid must adhere without defining chemical composition. Those specifications relate to boiling point of the fluid (both dry and wet), how viscous (flowable) the fluid is, and stability of the fluid at high temperatures among other properties. Succeeding generations of DOT fluid standards have raised the minimum boiling point. By the way, “dry” designates new, unused brake fluid with 0% water. “Wet” fluid is measured for the boiling point standard has absorbed up to 3.7% water.
While we make efforts to keep brake systems impervious and “dry” over time, even a buttoned-up brake system with tight seals and new lines absorbs some moisture. The key here is what happens to that moisture after it enters the system.
Absorption of water from humidity over time lowers the boiling point, making it more likely the fluid will boil. Picture summer driving in the city. The constant stop/start in traffic gets your calipers extra hot. This allows the fluid to boil as it reaches hot calipers. Gas or vapor formed when liquid reaches its boiling point allows the fluid to “compress,” making for longer travel when you apply the brakes. Typically, people describe this as having a “soft” brake pedal. In the worst of these situations, you may need to pump the brakes to have them take action.
The most common brake fluids—DOT 3 fluids are primarily glycol ether; DOT 4 fluids are also glycol-ether based, but have borate esters added to increase the boiling points. DOT 5 fluid was manufactured using silicone, which does not absorb water.
The point behind creating a silicone-based fluid was to avoid water absorption. Unfortunately, water still gets into the brake system, pooling or puddling rather than being absorbed into the fluid. That leads to corrosion in the system.
Most folks know they aren’t supposed to top off DOT 3 or 4 brake fluids with DOT 5, but don’t know why. The answer goes back to the chemistry. Combining even trace amounts of a glycol-based brake fluid with DOT 5 can cause the two incompatible fluids to gel, resulting in poor braking. Converting to DOT 5 also requires thorough flushing and removing ALL traces of the old fluid to avoid seal damage.
Let’s review: Brakes get wicked hot especially under extreme conditions. When the calipers (and the fluid reaching them) get hot, that fluid can—and will—boil. Boiling produces gas, which is more compressible than the fluid leading to soft, spongy brake pedal feel and a longer travel time when applying the brakes. As water enters the over time, hygroscopic brake fluid begins absorbing water from the atmosphere. Brake fluid containing water boils with less heat.
Our recommendation to most car enthusiasts is to go with a high-quality DOT 4 fluid. The higher-quality fluids offer a chemical makeup that is more resistant to moisture and contain the proper rust inhibitors we need for our classic cars.
Now, to wrap up, let’s talk frequency of changing out your old brake fluid. Put it on your once yearly maintenance list and you are likely pretty well covered. (A cautionary note here—you should change DOT 4 fluid more frequently than a DOT 3 fluid, because water will be absorbed more quickly in the DOT 4 fluid.)
Article Courtesy of Master Power Brakes
Chassis & Suspension Tech
Oct 11, 2021 09:08 PM
Jan 7, 2020 04:56 PM
treekiller
Jan 27, 2010 09:44 AM
skunk2eg
Apr 20, 2004 04:39 AM
b16aRacer
Feb 24, 2002 01:44 AM
