Why Do Car Batteries Die in Winter?
[h=2]Why Do Car Batteries Die in Winter?[/h] November 7, 2016 by Christa Hogan
Few things are more frustrating than climbing into a cold, snow-covered car or truck only to hear the dreaded “click-click” of a dead battery. It happens to the best of us. But why does a car battery’s life seems to end more frequently in winter? Read on for the reason why.
Source | Flickr
[h=2]The inner life of your vehicle’s battery[/h] First, a quick refresher on the science happening inside a car battery. Lead acid batteries are the most common car batteries because they’re inexpensive and fairly dependable. They’re made of a plastic case that houses a series of lead plates immersed in a pool of electrolyte—a mix of water and sulfuric acid. Each pair of plates makes up one “cell.” When fully charged, each cell in a lead acid battery produces 2.1 volts. So, a 12-volt battery consists of six cells.
The lead acid battery doesn’t produce a charge, but receives and stores an initial charge through a chemical reaction between the cell’s lead plates and the electrolyte. But as the chemical reaction occurs, the positive and negative lead plates are slowly coated with lead sulfate. This process is known as sulfation, and it reduces your battery’s ability to hold a full charge.
To complicate matters, lead acid batteries experience self-discharge, a natural loss of charge over time. Left too long without a fresh charge, a battery can discharge beyond recovery.
[h=2]So why do batteries fail in winter?[/h] Extreme heat or cold can increase your battery’s rate of discharge, making winter a triple-threat to your battery. All that exposure to summer’s heat evaporates the water in the electrolyte, increasing sulfation. Then winter rolls around, and freezing temperatures slow the chemical reactions occurring inside a lead acid battery, further reducing your battery’s ability to perform.
At the same time, a cold engine and sluggish oil demand more power, while power-hungry features like heat and defrost place more demand on your battery. Although lead acid batteries last an average of four years, they can fail earlier under the right (or wrong) conditions.
[h=2]Signs of a failing battery[/h] Your battery won’t always warn you before it fails, but here are common signs to watch for:
Source | Flickr[h=2]The inner life of your vehicle’s battery[/h] First, a quick refresher on the science happening inside a car battery. Lead acid batteries are the most common car batteries because they’re inexpensive and fairly dependable. They’re made of a plastic case that houses a series of lead plates immersed in a pool of electrolyte—a mix of water and sulfuric acid. Each pair of plates makes up one “cell.” When fully charged, each cell in a lead acid battery produces 2.1 volts. So, a 12-volt battery consists of six cells.
May 18, 2013 11:35 AM
