Cooling System Maintenance Tips
Old Dec 17, 2014 | 11:12 AM
Default Cooling System Maintenance Tips
A cloud of steam rising out of an open car hood usually indicates that the engine has overheated. Many people blame this on radiator problems, but the radiator is just one component of a larger system.
The cooling system is a series of parts that work together to pump coolant—typically a 50/50 mix of water and ethylene glycol (or antifreeze)—from the radiator through the engine to absorb heat and circulate it back to the radiator to transfer the heat through cooling fins and into the air. So before you blame the radiator for your car losing its cool, check to make sure the problem isn’t being caused by one of the many other parts of the cooling system. The most common cooling system problems involve one or more of the following:
· Thermostat - the thermostat controls how much coolant flows into and out of the radiator to maintain the ideal operating temperature. The valve inside the thermostat can get stuck open or closed by silt, rust particles, and residue, causing the engine to overheat.
· Radiator Hoses and Hose Clamps - over time hoses break down and clamps corrode causing leaks in the cooling system. Radiator hoses should be inspected at least twice a year, typically in the spring and fall, and replaced every four years or as needed.
· Water Pump - these fail when the shaft seal starts to leak or the impeller inside breaks, comes loose or the blades erode and wear. Without a properly functioning water pump, your car's engine will be subjected to extreme temperatures which can cause serious engine damage.
· Radiator Cooling Fan - if your vehicle starts to overheat while idling or operating at a low speed, check the fuse or wires to the electric cooling fan to make sure they are working and connected properly. If your vehicle has a belt-driven manual fan, (with the engine off) check the fan clutch that holds the fan in place. It should be free of leaks and have slight resistance when you spin the fan. Also check for play or wobble in the shaft, which can be the result of a bad water pump or a failing fan clutch.
· Obstructions - these can take the shape of engine "scale" blocking the cooling passages in the engine or radiator. Or they can be anything that restricts the flow of air through the radiator, such as bent fins, debris or body damage from an accident.
To keep your radiator in tip-top shape, it’s important to maintain proper coolant levels and flush the coolant system out as often as your car's manual suggests. General wear and tear and the age of your car will affect the efficiency and durability of your radiator. A properly maintained radiator can improve your gas mileage and the overall efficiency of your vehicle. Take good care of your radiator and it can last for 8–10 years, maybe even longer.
F4A22
Nov 22, 2003 05:35 PM
MILKMAN
Sep 10, 2002 09:31 PM
94teg
Feb 25, 2002 09:13 PM
