Tires...
Old Jan 14, 2003 | 08:21 PM
0HP930's Avatar
Guest
Originally posted by "PseudoRealityX"
Originally Posted by 400HP930
When trying to make up your mind on your choices, refer to the UTQG.
http://www.tirerack.com/tires/tiretech/general/utqg.htm
One thing to note is that the utqg treadwear ratings are specific to each brand. A 200 treadwear Yokohama has absolutely ZERO comparable value to a 200 treadwear Bridgestone.
Simply put, you cannot compare numbers from one manufactuer to another.
Yes, they do not exactly correlate since the gov leaves the testing to the manufacturer and their testing methods will differ.
I would not say there is no corrolation though. While it varies, the difference between 50, 150 and 300 are clear enough to allow you to guage the approximate wear characteristics and stickyness of a tire.
Old Jan 14, 2003 | 08:28 PM
StreetDriven's Avatar
I <3 your mom
Originally posted by "flounder"
Hey Nick look on www.tirerack.com They are selling off all the Yokohama AVS Intermediates fairly cheap since they've been discontinued.
I just bought 2 more for my maxima, there alittle to low of profile but they will work--> 230 40 17's
Old Jan 15, 2003 | 12:54 PM
PseudoRealityX's Avatar
cone junkie
True enough... Falken Azenis are rated at 200... Yokohama A520s were 140... That's humourous if you've driven on both.
-93 MR2, #129 ES
Old Jan 15, 2003 | 06:37 PM
Laurentz's Avatar
TR Balla Donor Supreme
You have a deathwish if you take S03's out in anything but spring/summer weather.
Old Jan 16, 2003 | 06:56 AM
m0nk3y's Avatar
pwns.
tirerack =
ordered at like 4 pm Jan 14th, arrived 9 AM Jan 16th.
now... the wait to see if my wheels arrived
Originally Posted by Lil Ze
Florida is the new Miami through and through.
Old Jan 16, 2003 | 09:16 AM
cone junkie
hehe, they are quite a bit better than the S-02s that they replaced to as far as wet traction.
-93 MR2, #129 ES
