Any write ups on pigtail terminal repair ? Rewiring
Old Sep 4, 2011 | 09:59 AM
Blu813SD's Avatar
I Want a Damn 240 Coupe
Default Any write ups on pigtail terminal repair ? Rewiring
I'm stuck in the position of rewiring a pigtail. I have no means of transportation and wanted to know if there are any writes up on how to repair pigtail connections of a terminal.
My coolant temp sensor and knock sensor pigtail pretty much wore out and broke off right at the edge of the connector and I wanted to remove the crimped connection from inside the terminal and run fresh crimped wires from it.
I know with computer wiring most terminals use a latch on the inside and you can release this latch by sticking a bobby pin inside while pulling on the wiring. Not sure if it's the same as automotive but if anyone knows of any write ups or how to remove the connections from inside the terminal post it up.
Old Sep 4, 2011 | 10:08 AM
Blu813SD's Avatar
Basically like a molex pin remover but somehow removing pins from a pigtail connector. I know a lot of these are made different but the concept is pretty much the same.
Old Sep 4, 2011 | 04:59 PM
Nycist's Avatar
NY Till I Die....
Google is your friend....
Originally Posted by Lime_Green_Hatch
$350,000 in 2 years... and all they had to show for it was some shitty hondas, lol.
R.I.P. Steven Daniel Berry a.k.a. Bush
Old Sep 4, 2011 | 06:46 PM
Blu813SD's Avatar
I thought TR was too. But guess I was wrong.
Post something if you know, hence the reason i'm asking here. Cause obviously I haven't found anything on Google.
Old Sep 5, 2011 | 09:20 AM
radkins's Avatar
You should be able to release the pin from the front side with a small screwdriver. What kind of car?
Old Sep 5, 2011 | 10:46 AM
BoostedRacerDad's Avatar
Pops
How to remove/replace pins in harness connectors - DSM Forums
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Sep 5, 2011 | 05:36 PM
Blu813SD's Avatar
Thank you!
and radkins it's a 92 240sx ka24de
Old Sep 6, 2011 | 04:33 PM
radkins's Avatar
Originally Posted by Blu813SD
Thank you!
Cool. I have a 93 fastback with an SR. I will out to the garage and look.
green88crx
May 5, 2008 12:28 PM
bustednut
Nissan/Infiniti Tech
12
Jul 9, 2005 08:32 AM
slovvcrx
May 17, 2003 02:05 AM
