i have a question??????
ok so it looks like my best bet is to pull the motor and replace the rings?
seffner meet getting started so click here to get in
https://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html
*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
https://www.tamparacing.com/forums/local-events/745189-seffne-meet-lets-get-something-started.html*ad removed*contact admin@tamparacing.com to ADVERTISE on here....
Nope ,but i been a mechanic for 15 years . why?
this is a similar method we use to break in the engines
Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
yes sir i do
My shit still slow
618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
stock block ,more power coming soon ,stay tuned
Tuned by Alpha @ Induction Performance
My shit still slow618 whp 492 ft/lbs at 22 psi (Low Boost)on pump gas ,
Babilla,
I think you know your craft.-Bob
does it look like it has a fresh motor in it ? Pretty easy to tell , if you know what to look for. Or does it look like the head has been off recently ? Or does it look like an oil leaking peice of shit? I can't understand why people get them selves involved with a performance car or " built " car if they have no idea how to fix it themselves. Maybe its because I'm an auto tech and not a parts changer , but if you cant tell from those compression readings that you have a peice of shit , you will always have a peice of shit that you are trying to fix. If someone says they just built it , but it still needs to be broken in , they are probably full of shit. I have built many cars , for my self and customers , and as a professional , not one car has left my shop with out being completely broken in. And I have NEVER had an engine falure.
PSA: No one gives a shit what you do or dont understand or what you do or dont do for a living. The OP has a problem if you cant help then dont waste everyone's time.
The funniest thing about this particular signature is that by the time you realise it doesn't say anything it's too late to stop reading it.
Are you offended because the same thing has happened to you ? My point is , you are a dumb ass if you get yourself into a car like this and have no idea how to fix it. And if you dont like what I say , dont read it.
