Hesitant when floored.
Old Jul 16, 2010 | 08:22 AM
John's Avatar
lol @ tampa
could be an air leak, check all your connections from MAF to throttle body and all vac hoses. If nothing, then I'd try some STP gas treatment, which will take out the water out of the gas. Those are your most likely culprits
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
Old Jul 16, 2010 | 12:44 PM
JaxS13Racer's Avatar
Sold my sol for Silvia
The rear bank might be starved a little. Try the fuel filter and if that doesn't work take off the tiny stock fuel rail loop on the tranny side of the fuel rails and check it to make sure nothing is clogging it. That is of course if it's not something simpler.
Old Jul 17, 2010 | 04:27 AM
Prowlin_Pasco's Avatar
has cheezburger
That was my first thought as well. A leak under high vacuum could cause the wastegate to stay open, when you ease up the leak lessens or stops and allows it to close.
With the age of the car and the underhood heat from 2 turbos it might be a good idea to replace your vacuum lines if it has never been done before.
Old Jul 17, 2010 | 06:19 AM
rotarykidd's Avatar
ROTM February 2013
this. cheapest first. and if its clogged it will cause all of what you said. my fb rx7 would run fine under half throttle, but as soon as i went half throttle to WOT, it fell on its face. to the point where it wouldnt even run. replaced a bunch of shit and i still couldnt figure it out. turned out, it was the fuel filter the entire time.
always replace the cheapest stuff first.
Old Jul 17, 2010 | 06:44 AM
95w_bTEG's Avatar
!!PORTUGAL!!
try fuel filter, or it could be fuel pump. get a fuel pressure gauge and see what the psi is.
Old Jul 17, 2010 | 07:54 AM
Petitt's Avatar
The Riot Society
Sorry forgot to mention the car is N/A lol
Thanks for all the suggestions guys. I have off tomorrow so I'll let you know what I find.
Old Jul 17, 2010 | 08:16 AM
  #17 (permalink)
quiksilvia's Avatar
Shit didnt know you had a 3kgt
That's what my roommate has lol
we just pulled the wire's off the coilpack and tested it that way
saw that number 5 was getting inconsistent spark
Try this and if it is bad go to advanced they were the cheapest around
hope it works out
VV Pasco Meet every friday! VV
Awesome Pasco Car meet evey Friday!
Originally Posted by EclipseGT01
Try and get people at ANY car show to come around a Grand Prix or a Regal.... they simply wont because there is a lack of interest in those cars. Not saying they can't be fast... just saying that my WRX will always attract more pussy than your pontiac
[Insert Awesome witty car list here]
[§]Hellabroke Ballin aint free! [§]
Old Jul 17, 2010 | 08:37 AM
  #18 (permalink)
S60R's Avatar
5 Cylinders Of Fury
Check the fuel pressure, its the easiest way you can make sure everything from the pump to the filter and regulator are working correctly. If you are careful you can even do it with a tire pressure gauge on the test port.
If that's good then start looking for plumbing leaks. If there are none then it could also be a bad MAF or MAP sensor as well.
2004 S60R - 350+ HP, AWD, Custom FMIC & Exhaust, Active Suspension & A Big Set Of Brembos
Crazy Camber, Stretch & Poke; its the new triple-stack-bleacher-wing ricer fad that's all the rage nowadays, lol
Old Jul 19, 2010 | 01:05 AM
  #19 (permalink)
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
I dont know a whole lot about 6G72s, but does it have a variable TPS? It sounds like that being out of calibration or dead is also a possibility. I also am not sure how dependent the ECU is on the TPS, but in some Japanese cars like mine, it practically doesnt care if it's plugged in or not. The only differences you'll notice are worse MPGs and the problem youve described.
ASE: Brakes
Old Jul 19, 2010 | 06:49 AM
  #20 (permalink)
DarksideZ's Avatar
TR Balla Donor Supreme
How old are the spark plugs/wires/fuel filter? Any vacuum leaks? I would try regular maintenance items first such as those.
