Any got an oil pressure gauge i can borrow?
Old Jan 18, 2010 | 05:11 AM
freakasis's Avatar
Default Any got an oil pressure gauge i can borrow?
got a flickering light on my accord and i dont wanna drive it until i make sure its not actually the oil pressure. it would be nice if your close to st pete since i will have to get a ride. thanks
"Black people can't be racist" - Some black guy.
Old Jan 18, 2010 | 05:20 AM
CoRDiTe's Avatar
Not Mad
Autozone lets you borrow tools. You should see if they have one to borrow.. You must put down a small deposit so they know they will get their tool back. Well worth it. You get your money back in full when your done using it.
Edit:
1) Have you checked your dipstick to see if you might be a little low on oil ??
2) Does the light flicker when you make a left or right turn ??
3) Does it start to flicker when you press the brake ??
4) Does it start to flicker when you are at a complete stop ??
Old Jan 18, 2010 | 04:23 PM
freakasis's Avatar
AZ doesnt loan an oil pressure gauge, i checked. so i bought one from harbor freight today. it flickers when idling. the oil was low the first time it came on and i was due for a change so i changed it. its full now and i still have the problem. the idle is a little low (500rpm), but i wouldnt think the oil light should come on at that speed. ill be checking the pressure in the morning. i hope its just the pressure switch.
Old Jan 18, 2010 | 09:05 PM
CoRDiTe's Avatar
Not Mad
^ if it flickers while at idle without moving vehicle it might be the sensor.. Hopefully it isn't anything serious.
Old Jan 19, 2010 | 04:34 PM
freakasis's Avatar
tried to take it off this morning. the dam rubber thing was solid as a rock. i think im gonna have to take the manifold off and chisel it away.
Old Jan 19, 2010 | 04:44 PM
CoRDiTe's Avatar
Not Mad
hmm what if the oil pump is going bad ?
Old Jan 19, 2010 | 05:06 PM
1BADP71's Avatar
E & I Certified
Or clogged. he can pull his oil pan and check that out... but that also requires removing some of the exhaust components.
I'm not 100% familiar with the system, so I can't say if it would read high or low with a clogged pump.
Old Jan 23, 2010 | 01:57 PM
freakasis's Avatar
tomorrow i'll have time to get that rubber (or what used to be rubber) off and check the pressure.
Old Jan 24, 2010 | 01:57 PM
Da_lurker's Avatar
does the engine knock? 500rshared_pm idle is pretty low, low idle speed = lower oil pressure as the oil pump turns slower also
