TRannys
Old Apr 29, 2002 | 05:27 PM
94Egsr's Avatar
I need some help guys I got a nasty leak in my tranny and im prolly gonna need a new clutch too.....just wondering if anyone has a hook up or knows of a shop that does good tranny work...im thinking about a LSD and a 2100....anyone have any suggestions ill take them...
Aaron
~GST~
Old Apr 29, 2002 | 05:49 PM
Tom N's Avatar
Non DSM.....DSM guy
Jerry aka lancerman #813-932-7440 he did mine and it works great.All he does is fix dsm`s and his prices are the best.
There is also george at foriegn conection he does good work to 813-987-2468.They are both in tampa.Jerry is also the parts god he can get you all kinds of good used stuff.
Tom
Old Apr 29, 2002 | 05:53 PM
94Egsr's Avatar
yea...no doubt i would have no problem having a badass that built that mirage get my tranny workin....i call him on tuesday
Aaron
~GST~
Old Apr 29, 2002 | 05:55 PM
Mr 2's Avatar
New Member
Dont know what your plans are but with an LSD and alot of power the 2100 is alittle weak I have one and it isnt enough
Old Apr 29, 2002 | 06:01 PM
Tom N's Avatar
Non DSM.....DSM guy
Originally posted by "Someone"
agreed get a 2600 lb and a baycity disk.Jerry will hook you up.
Tom
Fisch's Avatar
Depending on how much you drive the car you may want a 2600. Its a pain in traffic though and your left leg will get bigger than your right but itll grip like hell. Jerry did work on my eclipse by far the best work around. One last thing be sure to use the FACTORY throw out bearing. Theyre pretty cheap and a much higher quality piece.
Old Apr 29, 2002 | 06:03 PM
94Egsr's Avatar
just the person i was looking to talk to ......just wondering what setup you have as a LSD....also i heard a lot of crankwalk victims are born with the 2600...is that the nature of the beast or is just because people buy bigger clutches for more power?
Aaron
~GST~
Fisch's Avatar
Almost forgot you want a steel backed baycity disc.
Old Apr 29, 2002 | 06:19 PM
Mr 2's Avatar
New Member
It is hard to say what the REAL cause of CW is some people get it some dont. Using a clutch with a heavier spring will accelerate CW if you have it. TIP dont hold the clutch in unless you are moving like put it in neutral at stop lights traffic jams etc.
As far as chioce if you plan to run 13.0+ just get the 2100 but if you want to go faster I would get the 2600. however I am running the 2100 now but I can feel its weakness if you launch when it is still hot.
Old Apr 29, 2002 | 06:30 PM
94Egsr's Avatar
i think im gonna try the 2600 then .....i just gotta save about 600 more so i can get a good diff. thanks for the help and keep it coming....thanks
Aaron
~GST~
