Radiator leak
Old Jan 4, 2010 | 09:02 AM
SayWhaa?'s Avatar
they call me baby Jesus
Default Radiator leak
so i have a radiator leak coming from the radiator and not the hoses (not a bad leak just dripping). i read this is a common problem and it starts leaking worse when it gets cold outside. is there any stuff to pour in the radiator to kind of stop the leaking?
thanks.
say whaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Old Jan 4, 2010 | 09:41 AM
John's Avatar
lol @ tampa
theres a few commercial products available, or you can can put an egg in your rad (that is not a joke)
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
K20A2's Avatar
OH LAWD JESUS ITS A FIRE!
Radiator leaking is a common problem?!
-Winston Churchill
Old Jan 4, 2010 | 09:55 AM
SayWhaa?'s Avatar
not common as in it happens to all rangers, but it is a problem that many rangers have.
Old Jan 4, 2010 | 10:03 AM
302GTS's Avatar
Resident TOB Killer
Bar's stop leak will work. The leak will only get worse - it's a crack in the radiator. The egg trick DOES work, temporarily, but do you really want chunks of egg floating around your cooling system, through the heads, through the block, etc?
Old Jan 4, 2010 | 10:46 AM
SayWhaa?'s Avatar
ya i just need it to be a temp fix for now until i save up some more money.
Old Jan 4, 2010 | 12:51 PM
iglOo's Avatar
Euro Rat !!
+1 for bar's , did the trick on my old range.
SILLY RICERS, USELESS WINGS ARE FOR PENGUINS!!
Bought Not Broken!!!
Member#1
EuroRat
http://www.facebook.com/home.php?
Old Jan 4, 2010 | 12:52 PM
SayWhaa?'s Avatar
Originally Posted by P057
get a new radiator, they're generally cheap. just make sure you get the right sized one.
I hated using the stupid pour-in junk they sold for radiator fixes. caused more problems later than solved... Only solution was getting a new one, which was only about 150 bucks.
Tru, thanks for the info on that part. guess ill suck it up and charge a new radiator
Old Jan 4, 2010 | 01:40 PM
edmel89's Avatar
That One Guy
I'll never trust them quick fixes..
I had a friend use them "Stop leak" from auto zone on his radiator......
2 months later... BAM! He got cancer....
Old Jan 4, 2010 | 02:15 PM
Puto's Avatar
El Puto ©
JB Weld?
