Differences between wet and dry
Old Feb 25, 2002 | 06:11 AM
Epicman's Avatar
Me angry, you cry
Whats the difference between a wet and a dry nos kit???
Old Feb 25, 2002 | 06:48 AM
dan's Avatar
dan
Get the fuck off my lawn
dry is pure nitrous sprayed into intake i think
wet is usually mixed with fuel and plumbed into intake manifold
direct port is wet i believe and involves similar things to wet but diff setup i am unsure
Old Feb 25, 2002 | 09:09 AM
Mr 2's Avatar
New Member
Dry kits will spray nitrous into the intake stream before the throttle body with no feul. dry kits usually however come with a nitrous regulator that shoots around 20+ psi of nitrous to your fuel pressure regulator causing an increase in feul pressure to make up for the added o2 in the nitrous. This is good for NA cars using less than 100 hp increase with nitrous
Wet kits are like dry kits however instead of increasing the fuel pressure they spray fuel into the intake with the nitrous.
Direct Port is when the nitrous is sprayed into your intake manafold runners each runner has a small nitrous nozzel that is tapped into the manafold right before the head causing all the cylinders to have an equal nitous charge.
Old Feb 27, 2002 | 12:16 PM
Mr 2's Avatar
New Member
Originally posted by "Someone"
Originally posted by FordMan
Well some of the above is correct. Here is the rest.
A dry kit sprays into the intake system. I do not know where you guys are getting the fuel pressure bump from unless there is some off brand kit that does this. It is usually up to the installer to add on a fuel pressure regulator to raise the pressure. Pressure only needs to be raised a few pounds. A dry kit can be used up to a 100 shot.
And there you have it your nitorous 101 class is now complete. Hope that helps.
Dont mean to be rude but your statment sounds like you are pushing us out of the way and saying we are wrong.... First thing I want to say is...It is nitrous he is asking about not NOS. second NOS makes several of those off brand kits as well as ZEX and they for EFI cars as most people have now. reread my post and you will see I said usually as that IS the case.
