R.I.P. Speedvision
Originally posted by "Someone"
Originally posted by IntegraRacerGirl
Why where is it going??? Did your cable get shut off or
something?
something?
out by I believe Fox and is now the Speed Channel. They
basically took away all the good stuff and shoehorned in NASCAR.
One of the main reasons I loved Speedvision was because there was
no NASCAR to be seen. So much for that
R.I.P. - Jason Harrill - 6/12/06
"Well, here's the thing".....you will be missed.
Guest
Posts: n/a
now now it may be nothing but nascar now give them a little bit of time a month at most and youll see familar stuff returning. They still plan on keeping rally cart f-1 (licensing agreements in the process between the 2 right now) and all the other bad ass stuff. The last year of speedvision has sucked with all that boat and airplane bs. From all the reading Ive done on the subject it seems as if the only change is nascar will be taking the place of boats and airplanes and the other stuff will remain. Just give them a little bit of time to get broadcasting worked out.
Robster
Robster
Guest
Posts: n/a
Originally posted by flounder
The only thing worse than NASCAR is NASTRUCK.
