Breaking in an engine
Old Feb 10, 2002 | 10:54 PM
CrazyMoparGirl's Avatar
Guest
Are you using a new cam? If not just be easy the first 500-1000 miles and you should be fine then change the oil and your done. If you have a new cam its different. Vary rpm from 1500-2500 for approx 30 min then change oil and drive easy for 500-1000 miles then change oil. At least thats what we did we did jump into some high speed for a minute or so but we didnt need to because the way the engine was built torque plate and rings. Forgot to mention the ynthetic oil thing Bad for break in very bad. especially if some of the assembly lube is still on the internal components. Dont forget to prime (oil) her before you crank her over.
Old Feb 10, 2002 | 11:10 PM
Guest
Just turm your cell on Ill call ya easier than typing.
Old Feb 12, 2002 | 11:05 AM
LogicalRetard's Avatar
Cafe Racer Extraordinaire
All those NHRA guys just stick one in and go at it but they also
have like 20 backups. From what Ive heard from all the
experienced engine builders they say that new cars dont need
break ins anymore just more oil changes the first few thousand
miles. Built engines should still be broken in built meaning not
in a new
R.I.P. - Jason Harrill - 6/12/06
"Well, here's the thing".....you will be missed.
Old Feb 12, 2002 | 02:33 PM
HybridSS's Avatar
I have fuzzy eyebrows
Well...I had my motor built by Agostino Racing in Canada. A famous Chevy engine builder. His advice to me was surprising to say the least. He said start it up check everything thouroughly like oil pressure leaks etc. Drive it around the block a few times. Bring it back and let it cool down repeat several times. Then strap it to the dyno and let it fly...Doh! I couldnt bring myself to do this though. I put about 500 on it before i started hammering the motor.
He did stress NOT to use synthetic oil for at least 4000 miles.
Thats my story and Im sticking to it.....Al
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Feb 12, 2002 | 03:21 PM
HybridSS's Avatar
From what I understand synthetic oils actually lubricate a little TOO well for the piston rings to seat properly. Seating rings is nothing more than grinding away the high spots until the sufaces mate well. Syn lubes dont allow this to happen properly.
Garrett
Mar 13, 2001 12:10 PM
blondtoker
Mar 13, 2001 12:54 AM
Ralph
Oct 30, 2000 04:59 AM
Charles
Nissan/Infiniti Tech
Oct 2, 2000 11:31 AM
superman
4
Oct 1, 2000 05:09 PM
