Someone tell me a bit about E85
Old Mar 14, 2009 | 03:24 PM
shonanspeed's Avatar
TR Balla Donor Supreme
Default Someone tell me a bit about E85
The gas stations on base near me just got E85. I heard it has a higher octane rating than 93. Anyone using it? Is this the new poor man's race gas?
Old Mar 14, 2009 | 03:59 PM
JDMBlackGSR's Avatar
Gators Bitches!
E85 - Wikipedia, the free encyclopedia
2003 Accord EX-L V6
Interior
'07 Shift Lever♦Diode Dynamics Stage 1 LED's
Exterior
HFP Front & Rear Lip♦Limo Tint♦LED Smoke Tails♦Yellow Fogs♦8000k Low Beam HIDs♦LED Reverse Bulbs♦Gunmetal Stock 7 Spokes
Suspension
Rear Lower Tie-Bar♦Front Strut Bar♦TL-S Rear Sway Bar♦MOOG Rear Endlinks♦HFP Suspension♦Ingalls Camber Kit
Engine/Performance
Nokya Battery Tie Down♦Spoon Radiator/Oil Cap♦Skunk2 Clutch Cover♦Stainless Brake Lines♦TL Engine Cover♦RV6 J-Pipe & Test Pipe♦Short Ram Intake
Old Mar 14, 2009 | 04:42 PM
Thanks
Old Mar 14, 2009 | 06:39 PM
goefyourself's Avatar
Janky Crew
there was a guy in columbus ohio that put down some pretty good numbers with e85 with his single slam...355 whp. it burnt really clean too!
www.JankyProductions.com
We know the streets better than the whores on the corner.
TR "Old Skool EF" Member #128
Old Mar 14, 2009 | 08:07 PM
Yeah but whats this shit about not having any aluminum components in your fuel system? Isn't E85 supposed to be for flex fuel cars with the upgraded fuel tanks? I just wanted to see if anyone was running it with any neg or positive effects.
Old Mar 14, 2009 | 08:54 PM
Boostin'Xr4's Avatar
Can you dig it?
I can't imagine there being THAT much of a difference, as what we run at your average Florida pump is basically E10.
A big turbo stang and a big turbo truck.
Old Mar 14, 2009 | 09:01 PM
Alpha's Avatar
There is a HUGE difference between E85 and E10. We've been using and tuning E85 for a while now. We're starting to use and tune E100 also. If you use the E85 be aware you're going to have to do a lot more tuning both with fuel and ignition but mainly fuel. Ontop of that it requires on average 25% - 35% more fuel ontop of 93 octane fuel values. We've made some very good power on both E85 and E100
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old Mar 14, 2009 | 09:42 PM
Can you dig it?
Good to know, thanks!
Old Mar 15, 2009 | 07:08 AM
shinmei2006's Avatar
koenigsegg ccxr made like 900hp on 91, and 1100 on e85. something about e85 having a cooling effect on the engine?
http://www.hashiriya.net
Old Mar 15, 2009 | 09:44 AM
Prowlin_Pasco's Avatar
has cheezburger
I dont know much about the performance side, other than the fact it takes more ethanol than gasoline to produce XX amount of power, but ethanol is corrosive to normal gasoline fuel systems. To run it the system has to be made for ethanol.
