flooded my car.
long story short.
i drove through a flood and now my car will not turn on. it was about 3/4 ft of water. when i go to turn it on it clicks but does not turn over.
anyone ever had this problem or know what i do.
serious help please....
Ben.
Ben.
[SIGPIC][/SIGPIC]
[SIGPIC][/SIGPIC]
Like you covered your intake with water (= hydrolock) or you just got some electronics wet and now the starter won't work.
Pull your spark plugs, tun it over, see what happens, also video tape that, you know for posterity reasons.
"They must really feed each other to the lions down there........"
Well, what you're dealing with right now sounds more like an electrical issue. You may have killed your starter when you dunked it and now all you're hearing is the click of the starter solenoid. I believe I recall an instance when my friend drove his Supra through a deep puddle and when he got back to the car it wouldn't start, and he ended up having to replace the starter in a USF parking lot. I'd just pop the hood and try to let things dry out (easier if you have a garage or if it doesn't rain like it did today, heh).
Before you try to start it again I'd pull the spark plugs as a precaution. If there's still water in the cylinders you could do more harm when it finally cranks. You want to blow the cylinders out by cranking it for a good 30 seconds with the spark plugs out to make sure there's not any water trapped in the cylinders. Often the engine will choke out when the intake sucks pure water and it will stall before it tries to compress water and you run into true hydrolock. Hopefully this is the case and you have no bent rods, cracked pistons, holes in the block, or other nastiness that can occur with true hydrolock.
So anyway, try to let her dry out, if that doesn't get her cranking start tracing the electrics for the ignition and starter system and replace/repair, pull the plugs and crank her over and hopefully it will all work out for you.
yeai know same my bro happen and u should take off head again and in ur water fill on piston u need clean up dry better put back head and u should buy new gasket head
-Winston Churchill
-Winston Churchill
hehe, people like you guys make me giggle.
Anytime it rains a little hard out, there's bound to be a thread somewhere "my caaaar flooded....... waaaaaaaah."
stop pretending your car is a kayak.
Quote of the year for sure.
