bmw problem...again
Old Apr 7, 2008 | 11:20 AM
Mafiakiller's Avatar
Ballin Beretta
Default bmw problem...again
i have a '87 BMW 528e with a '83 533i motor...well this morning started up fine...after school started up fine...drove home...about 10min later wont start up. it will crank up but wont start.....if someone can help me that will be great. thank you.
I should have kept my integra
Old Apr 7, 2008 | 11:44 AM
Ballin Beretta
nvm it started again
Old Apr 7, 2008 | 11:48 AM
tito_12a's Avatar
starter problems ? my rx-7 usually does the same thing.
Old Apr 7, 2008 | 12:01 PM
Ballin Beretta
yeah it seems like it
Old Apr 7, 2008 | 12:40 PM
Aoshi's Avatar
chances are its not the start if its turning over. Because its so old it could be your fuel pump, or injectors getting a little clogged...or is it a carb setup?
In my limited experience when its turning over but not starting its usually a little lack of fuel. If it is a carb next time this happens, pour a little fuel into the carb and if it starts RIGHT away, then your having a lack of fuel problem.
Old Apr 7, 2008 | 01:13 PM
BlackWind's Avatar
Requiem
post...
okay
Old Apr 8, 2008 | 05:54 PM
Ballin Beretta
it did it again today...
morning-started up fine
after school-started up fine
got home...an hour later...it wont start...then 10min later it started....
does the BMW have a routine of when it wants to start and not to start lol.
Old Apr 9, 2008 | 04:57 AM
g-50Cab's Avatar
TR Balla Donor Supreme
Pretty sure it uses the same Bosch motronic that porsche uses - I recommend getting the service manual and following the trouble shooting guide. a no start can be anything from a simple relay (and on my car there is a $30 DME relay under the driver's seat that goes bad - carry a spare)to distributor to coil.
If the car will turn over it probably is not the starter.
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower"
-Mark Donohue
Old Apr 9, 2008 | 07:22 AM
K24_ELEMENT's Avatar
+1
Old Apr 9, 2008 | 07:58 AM
Flaco_GST's Avatar
Master of the cut-off T'S
My old car used to do that. When it was hot from just driving it it wouldn't start if I shut it off and tried to restart it but after letting it cool off for afew hours it would crank right up. It's your starter dude, change it and you should be fine. That's what I did.
...Only god can judge me...
"If you don't set goals for yourself, you are
doomed to work to achieve the goals of
someone else."
Women might be able to fake orgasms but us men can fake a whole relationship.
V-TEC = Virtually-Torqueless Economic Cars
(PROG) Crew member #5
{o,o}
|)__)
O RLY?
