bmw problem...again
if it will crank it's not the starter
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower"
-Mark Donohue
-Mark Donohue
my civic would do that sometimes, check ur fuel pump.
On the bosch cars there is a fuel pump relay - called the dme relay - that's the first thing I would replace and see if it clears up
-Mark Donohue
-Mark Donohue
I still have to finish my fuel pumps on my 325es and replacing the relays. Its been sitting for so long, Ive basically just given up on it.
I have a 1984 BMW 533i experiencing the same exact problem. The motor turns and all signals are great however it will not start.
For the DME help, go here.
Pelican Technical Article: BMW DME Motronic ECU Swap / Repair
"so persuasively did they talk; and yet there is hardly a word of truth in what they have said."
Plato, Apology
"On life's journey faith is nourishment, virtuous deeds are a shelter, wisdom is the light by day and right mindfulness is the protection by night. If a man lives a pure life, nothing can destroy him."
Buddha
Plato, Apology
Buddha
