Engine wash???
Engine cleaner is simply diesel gas... Use brake or carb cleaner. Then rinse away with simple green and water after.
I concur on the plastic grocery store bags. I even pack one inside the distributor..........remove it before starting! Bag that alternator just in case, and all the other stuff they said.-Bob
I blow off the dist wires at both ends with my air tank.
ok when i cleaned my motor i used Greased lightning and a toothbrush and made my motor look new got pic of before and after using greased lightning, just make sure u scrub it good and get all the oil off and make sure that u cover any electrical items that will not get destroyed.
Before
After
Before
After
I covered up important stuff with plastic bags
Sprayed the entire engine compartment with Greased Lightening and let it sit for about 30 min or so, then hosed it off regular hose pressure, nothing too forceful and the engine looked brand new.
Best thing about it, it's biodegradable.
I'm getting some of that stuff! It also adds a transmission and repaints
your valve cover!.............. I'm joking around.
Thanks for the pics.-Bob
Grease Lightening is good stuff.
