Injectors.
Old Jun 27, 2007 | 07:17 PM
SmokinS13SR20's Avatar
That ginger...
Default Injectors.
They only require a power source and a ground to function, correct?
Then they should spray fuel or whatever fluid a certain cfm @ w.e pressure is supplied to them?
Old Jun 27, 2007 | 07:50 PM
3drwhore's Avatar
Pending....
what car?
Old Jun 27, 2007 | 07:52 PM
That ginger...
Originally Posted by 3drwhore
what car?
None, just injectors in general.
Thinking of making a project...
Old Jun 27, 2007 | 07:56 PM
Silvia_San's Avatar
Private Parts Thug Lyfe
flamethrowers are bad.
Old Jun 27, 2007 | 07:57 PM
3drwhore's Avatar
Pending....
well injectors pulse, so if you were to hook up power to it and then ground it the injector would have a constant spray and not pulse like its meant to.
Old Jun 27, 2007 | 07:58 PM
3drwhore's Avatar
Pending....
yea I figured you want to make some sort of flame thrower or gun of some sort.
Old Jun 27, 2007 | 08:06 PM
3drwhore's Avatar
Pending....
so if you want to be able to spray the injector when you want. say your making a flame thrower, I would drill a hole in the top of the pipe that you are using big enough for the jet to fit in and then connect it to power using a 9v battery pack that you can mount on the pipe somewhere, then when you run your ground put a single pole single throw switch in there so you can control your ground with a switch. so when the switch is turned on it will complete the circut and you can pump fuel through the injector.
Old Jun 27, 2007 | 08:17 PM
That ginger...
Actually I wasn't thinking of a flame-thrower, but maybe I could make one and throw it on the cougar
Old Jun 27, 2007 | 08:20 PM
3drwhore's Avatar
Pending....
but to answer your question, yes all they need is power and ground to spray fuel, but they use a controlled ground so its not on at all times.
Old Jun 27, 2007 | 08:24 PM
That ginger...
Yea, I know they pulse that's fine I don't need them to...
I dont know how they would handle exhaust temps...
