interior tear out question
everything is posted in the link below.. thanks for the help and rep will be given.
-Mike
https://www.tamparacing.com/forums/t...questions.html
-Mike
If it's stuck on there, leave it alone. If its loose and or rotting out, tear it out.
If you're a stickler for road noise control, a good solution for deadening would be removing that crap (if its loose and cheap), if its somewhat smooth and decent to work with, I'd reccommend putting in some sound deadening material LIKE Dynamat, but you can usually find some other stuff much cheaper and easier to work with. I really prefer and love to use RAMMAT. This stuff is just about as good as Dynamat extreme but its the price of Dynamat regular and is a buttload easier to work with and doesn't cut up your hands as much.
If you need to know where you can get some, i know of a great shop that sells it for an awesome price.
well the reason im asking is my car had a windshield leak and the trunk leaked allowing water into the floor-board. I really dont want the floors of my car rotting out, and i really dont car about road noise either. so i figured it would be in my best interest to just yank this stuff out before it did allow the water to damage the floor.
thanks for the info
-Mike
thanks for the info
-Mike
On some cars, there is a tar-type material stuck to the floor in square sections. Sometimes it cracks and water gets on the metal through the cracks.
To remove it, put some crushed/broken up dry ice on it to harden it, and it comes off easier.
After cleaning where it was with mineral spirits/diesel fuel/fuel oil, I use cans of touchup paint to paint over where it was.-Bob
If you are talking about a fabric-scrap material, it definitely will absorb water and cause rust. Either dry it or remove it if it's damp/wet.
Be aware that it also works to slightly insulate from the heat.-Bob
i am going to take a picture of it right now. then you can see what i am talking about, maybe it will help more.
-Mike
-Mike
the non-wet part.
the wet part.
i have more pictures but my camera died while i was trying to upload them, hopefully this helps out some.
the wet part.
ok ty, whats the best way to remove this stuff cheaply?
