How To Pull Axles In An Lsd Rear End.. Help Asap!!!
Old Dec 29, 2006 | 07:55 AM
TIM TIM TIM's Avatar
could be worse
Default How To Pull Axles In An Lsd Rear End.. Help Asap!!!
my dad has a 95 chevy van and we are trying to replace the axle.. we got everything apart and there are little clips in the rear end that hold the axle in.. how do i get them off??? its a c-clip but it feels to strong to just bend out and i cant push it off either.. is there a special tool??? trick??? please help me asap/
aim:because tim said
Old Dec 29, 2006 | 07:59 AM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
C-clips use special tools. Depending on if its a inward clamp or outward clamp may require different handtools if you dont have the kind that are switchable
ASE: Brakes
Old Dec 29, 2006 | 08:03 AM
could be worse
like what kind of tool?? the axle where it attaches inside the diff there is a notch in the axle and then a clip over it... is it a tool advanced or somthing would let you rent? whats it called??
Old Dec 29, 2006 | 08:06 AM
Dano Moparo's Avatar
Grandpa
GO HERE
Changing Rearend Gears
Old Dec 29, 2006 | 08:10 AM
Just Dave's Avatar
Do It In The Dirt
Don't listen to Orian, he's thinking JDM again. First, take the cross pin out (its a big steel pin that sits between the axle shafts. Once that pin is out, push the axle in, and take the C-clip off with a pair of needle nose pliers. Repeat for the other side. Drink beer.
29 Hard and Single
My Rail Buggy
Old Dec 29, 2006 | 03:36 PM
could be worse
thanks very much for the site.. pretty odd, we had the bar out and all and for some reason the axle wouldnt push in far enough.. my dad just gave it a light kick and it fell right off.. the other side was fine lol..the axles werent broke, the van just carried tooo much weight on a daily basis and cause the bearings to were in the axle pretty bad
Old Dec 29, 2006 | 04:05 PM
Oops, no I was thinking of the other kind of c-clip, like the ones in ratchets and stuff, not the axle ones. Didnt think too hard about that.
ASE: Brakes
Old Dec 29, 2006 | 07:41 PM
Road Rage's Avatar
Shake n' Bake
+1 push axle in and pull it off, its really easy. why are you replacing just the axles anyways? check the bearings and housing...
Old Dec 30, 2006 | 06:46 AM
could be worse
bearings, seals and all are beeing done too.. we had to ge tthe axle out first though lol.
Old Dec 30, 2006 | 07:52 AM
Road Rage's Avatar
Shake n' Bake
well usually when the bearings go you have to buy a whole new rear end cause it tears up the housing...
