How To Pull Axles In An Lsd Rear End.. Help Asap!!!
Old Dec 30, 2006 | 11:26 PM
I concur with Dave's answer, except I use the stick with a magnet
to remove the clips.-Bob
Old Dec 31, 2006 | 09:03 AM
el_camino's Avatar
Originally Posted by Road Rage
well usually when the bearings go you have to buy a whole new rear end cause it tears up the housing...
there are "saver" bearing available as well. they don't sit on the worn part of the case and acts as a seal as well. i have one installed in my car's rear end. they cost around $40 or $50 but its a lot cheaper then replacing the whole thing.
Old Jan 5, 2007 | 11:55 AM
TIM TIM TIM's Avatar
could be worse
we already had those in there lol.
aim:because tim said
Old Jan 6, 2007 | 08:08 PM
When I have to make a bearing fit tightly into a slightly loose housing, sometimes knurling the opening is cheaper than replacing an entire housing..........plus some stud/bearing quality locktite.-Bob
