so uh..i coulda died..
I dont mean to agetate this anymore but the front drain holes are in the door jam. Once you open the door, you can see them above the hinge. Usually you can take the end of the hose and pinch it and watch the water run out. The rear ones are just underneath the bumper. The wheels dont need to come off for this job. The car doesnt even need to be jacked up to do this.
But then again, they may have done a tire rotation. Check your paper work.
Originally Posted by CanTheWhales
Hey buddy, check the first post, it says it drained into the inner fenderwell. I don't know about you, but I would take the tire off to work inside the fender...stop getting so pissed off and read all the way through an article once and a while.
I'm not pissed of my cars not the one that lost a wheel.
Originally Posted by theebluecrx
If they fixed a leak in your roof they probably had nothing to do with your bolts falling out.Shit they probably never drove your car and did a check if they didnt charge you for it.I hate morons that try to blame people/shops that didnt touch the part of thier car that failed after it leaves.If you go back you might get the $5.00 bolts you lost.
BUT, if they DID remove the wheel, then you have something on thier dumb ass's, and they suck at life
Boost...it's a hell-of-a drug
ok all of you VW genious's...if you know so fucking much you would know there is more than 1 drain...there is one in the door..and there is another one that you can access through the fender...so to make life fuckin easier they take the damn wheel off..just so you VW gods know..
if it was my fault i would blame myself..but being thrown into on comming traffic because some dick fuck didnt tighten my lugnuts and it wasnt my fault is a completely different story..
i know what the shop did..i have every receipt from every time they touched my car..
just do what i did, and get the conversion for studs instead of having those stupid ass lug bolts that all veedub's have, which suck. the same thing happened to me on 19 going home, so i got the stud conversion
Vincent Mancini : Don Lucchesi, you are a man of finance and politics. These things I don't understand.
Don Lucchesi : You understand guns?
Vincent Mancini: Yes.
Don Lucchesi: Finance is a gun. Politics is knowing when to pull the trigger.
