Sold the nitrous AND PICKED UP MY GARRETT :)
Old Jun 10, 2006 | 02:59 PM
02vortec's Avatar
Default Sold the nitrous AND PICKED UP MY GARRETT :)
the turbo is a T3/T4 from my friends 3SGTE build on his MR2- he made 406whp on it until he maxed it out. Since my goal is 320 to 330whp on boost it should be very good.
The turbo is a Garrett product, profesionally balanced, no shaft play, clipped, ported and spooled @ 2600 on his 2.0L 4cyl so i figure on my 4.3L is should SPOOL IMMEDIATLY which is a good thing. it still has a 1 year warranty on it so i think i got a good deal on it. paying $250 for it.
ordering 2.5" exhaust building kit maybe 2 of them, turbo xs 38mm wastegate, cartech fmu and walbro fuel pump tonight as well as GETTING all of my fluids changed to royal purple
Old Jun 10, 2006 | 03:01 PM
jlude90's Avatar
aspiring luder
....YAAYYY!!!!
what are plans?
i believe this is members rides tooo
Old Jun 10, 2006 | 03:07 PM
02vortec's Avatar
Originally Posted by jlude90
....YAAYYY!!!!
what are plans?
lol sorry i didnt quite now where 2 put it.
its actually gonna be an STS style turbo set-up. today im taking the whole front of the truck apart to get measurment it hard becasue i got a full time job, and school starts up in about two months. im having a hard time with turbo selection right now. im going sts because trtt turbos did a custom sts turbo on a blazer and @ 3.8 psi made 210whp and 270ft.lbs., that was on STOCK everything. NOthing else done to the truck.
i will be running methanol for some time with a cartech FMU and walbro intank fuel pump and AEM wideband. having a hard time deciding where to put the intercooled, either under the truck back next to the driveshaft with an e-fan on top, or on the front undereath the truck...... i will be running the piping under the the top of driver side fender its gonna be clsoe but i can fit a 2.5" pipe in there after soem measurments where taken. I am trying to do this so everyon can do a set-up like this. im on a budget, my money for this project is $1300 including turbo/intercooler/wastegate/oil pump and everything. looking for 300whp @ 10psi now which will be much safer and should put me around 400ft.lbs, then i will be throwing a 2800 to 3000 stall torque converter and an eaton posi with 3.73's and see if can hit very high 12's. also gonna get a hellsbent base tune to get it running. and then get a dynotune-
btw this is on stock bottom end/cam/valve train/ heads. i will have 1.6rr's put in but i really need some valve springs so i can run the rpms up higher- as for the bottom end a guy with a procharger set-up has hit 400whp and 400ft.lbs totally stock bottom end so i think my goals are very doable and not out of reach.
also once i get the turbo/meth totally tuned and get it running to its full potential calling up the folks over @ NX maybe yall know where im going with this......
Old Jun 10, 2006 | 04:27 PM
Brewtal's Avatar
that one guy
keep us up to date. I have been debating putting a turbo on my truck for a long time but haven't seen one done at a resonable price come out with some nice numbers. So I'm rootin for you.
Old Jun 10, 2006 | 05:05 PM
jlude90's Avatar
aspiring luder
awesome man, and this is in a blazer?
what year and whatnot
is this a daily too, or just a track car?
Old Jun 10, 2006 | 09:09 PM
02vortec's Avatar
daily. 4.3L w/ 4l60e a/t tranny. 2002 2wd 2door 38k miles.
