Boost PSI question
On average how much HP do you get per PSI of boost?
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
+1 as shown, though there are sooo many factors to concider..displacement, RPM, compressor efficiency, intercooler efficiency (if there is one) engine efficiency...
Rule of thumb is 10-11 HP per psi
ASE: Brakes
ASE: Brakes
Originally Posted by jlude90
yeah, don't DSMs run like twenty somethin pounds of boost?
they don't have like 200HP just off the turbo do they?
i could also be 100% wrong
ASE: Brakes
ASE: Brakes
stock boost for dsms is between 8.5-11lbs.
SUCH IS THE RULE OF HONOUR.
