Boost PSI question
Originally Posted by Superkaioken
so im running bout 235 hp??? since i boosted from 7 psi to 10.5?
What do you have, a standard sr20 swap- intake, front mount, turboback, untuned? Probably more like 200-210 whp on 10 pounds. Friend of mine did 220 on 14psi untuned with that same basic setup.
Originally Posted by Jordan Y.
Not that easy, it's 10hp per properly supported psi in the turbo's efficiency range. A small stock turbo starts blowing hot air pretty quickly, and the rule assumes all the supporting mods are there.
Originally Posted by ImportLuv
Drive my car around for 20 mins, it actually looses power, even at 14 psi, it feels like 1.
it's true.
When cold start, it feels good.
it's true.When cold start, it feels good.
Unless if your intercooler/intake just heats up too much from the lack of turbo efficiency, which factories love to do
Just ideas...dont quote me on that
ASE: Brakes
ASE: Brakes
Boost for the sake of boost is bad. Lots of factors to deal with. There are Buick GN's that can run 10's all day long on 10-15 psi boost, while my car needs 25+ psi boost to run with them. If your engine can flow a lot of air than you'll see more hp as you increase boost. At 17 psi boost my car made 403 rwhp 545 rwtq and at 25-27 psi boost it made 593 rwhp 695 rwtq. For arguments sake, it was 10 psi increase. It bumped rwhp by 190. This yields 19 hp per psi boost on my pushrod 3.8L V6 engine...For smaller engines it should be less until you start hogging out the head(s) and going to more cam.
The LSx generation of V8 engines also flow very well and each psi boost increase yields significant amounts of hp.
Originally Posted by Epstein
Plus he's adding HP to the stock flywheel number. 235 at the flywheel probably isn't that far off.
Oh, flywheel numbers. I only use those when I'm talking to people that know nothing about cars. Yeah, 235 doesn't sound unreasonable.
Basically I usually use flywheel because its more universal. I also use it because I'm modding my car the wrong way; putting performance parts as my goal on there and just seeing how much power I get out of it. Honestly I dont have a power goal...whatever my planned mods give me power wise is good enough for me
ASE: Brakes
ASE: Brakes
Originally Posted by CrypticApathy
On average how much HP do you get per PSI of boost?
It's stock, I swear!
