Need HELP!!...
Old Jan 30, 2006 | 05:34 AM
Daisylove1322's Avatar
~*Milfalicious*~
Default Need HELP!!...
I have a 99 VW Passat 1.8T, and for the past month or so once or twice a day I'll have problems getting it started. Or if it does start right up it will rev high then run ok, then may not start the next time. I can always get it going after a few tries, but I'm afraid I will get stuck somewhere, and have no clue what's wrong with it. Paul thinks the turbo may be going bad...any other ideas?
Thanks
Michelle
TF MILF Crew
Old Jan 30, 2006 | 05:41 AM
SkwervE's Avatar
realer than most
umm i dont think the turbo has much to do with it starting...post this in VW tech...bisquitman prolly could tell you whats wrong with it...take it to a VW dealer and have a mechanic look at it...
how high does it rev when you start it? and do you hear a click whenever it doesnt start?
Old Jan 30, 2006 | 05:43 AM
3drwhore's Avatar
Pending....
yea mine revs high when I first start it for about a minute then cools back down.. its normal for it to do that.
Old Jan 30, 2006 | 05:45 AM
SkwervE's Avatar
realer than most
thats what i was gonna say..thats why i asked how high it was going...
if its jumping up to like 2500+ something wrong..but mine will go up to 1100 and back down to idle..and thats only when its cold..
Old Jan 30, 2006 | 05:49 AM
~*Milfalicious*~
It jumps up pretty high (beween 3-4) and will sometimes bounce up and down, even when I start driving, (almost like it'll drive itself?) As for the starting, no clicks, it sounds like it wants to start, but takes like 4 tries before I can get it going??....
TF MILF Crew
Old Jan 30, 2006 | 09:28 AM
SkwervE's Avatar
realer than most
its your coilpacks or your MAF...check both....
Old Jan 30, 2006 | 11:53 AM
SpdRcrChk's Avatar
*PunKy b00SteR*
if the idle bounces up and down check to see if there's a vaccum leak. that sometimes causes the idle to bounce that way. as far as starting up check the starter maybe. my cousin had a passat....went back to the dealer 12 times in a year and a half.
anyway, hope that helps.
(\___/)
(")__(")
Old Jan 31, 2006 | 07:30 PM
MCokewell's Avatar
The Dude
http://www.vwfixx.com
