Im no engineer....
Old Jan 13, 2006 | 06:15 AM
Santos's Avatar
Default Im no engineer....
But if you could weld two s2000 motors together, that would make a nice V8 wouldnt it? or am i just bored at work? if so that would be my V8 and my V12 would have to be 2jz welded together....mmmm
v12tt 2jz....i wish...
what combos would you like to see...and if you are some sort of engineer or know anything about this, is it feasible...i know i cant afford it but just knowing if its possible would be cool....maybe ill hit the lotto one day
TR "Old Skool" DA member #60
Santos618 - Xbox 360 gamertag
GTA4
Forza 4
Madden 12
open to any good online games, i just suck at shooters lol
Old Jan 13, 2006 | 06:26 AM
SkwervE's Avatar
realer than most
definately not possible..
Old Jan 13, 2006 | 06:41 AM
CanTheWhales's Avatar
...Your Mom
Anythings possible, but the Lotto just isn't always enough...
Old Jan 13, 2006 | 07:05 AM
Epstein's Avatar
Retired
I am an engineer, but mechanical is not my forte. For the S2000 motor, there is little that could be welded together. It would be feasible to build a completely custom block based on the dimensions of "2 motors welded together", but it would be very costly in both machining and engineering. You'd also have to mirror one of the heads, so that the intake and exhaust would be on the correct side of the motor.
On a related note, I saw a shop's website that had built a V8 Hayabusa engine. I'll see if I can dig up a link.
Old Jan 13, 2006 | 07:09 AM
Santos's Avatar
not possible? jesse james made a car fly and you telling me thats not possible...lol...anything is possible in my book....
GTA4
Forza 4
Madden 12
Old Jan 13, 2006 | 07:12 AM
Duke_nukem's Avatar
for that just copy that guy that installed a 350 in a crx. now that is hotness.
_____________
91 Hatch B16-T
13.0 @ 110 - 7psi
--Even my Truck has Vtec--
Old Jan 13, 2006 | 07:16 AM
...Your Mom
Originally Posted by SilverGST
jesse james made a car fly....
I love that show
Old Jan 13, 2006 | 07:25 AM
Santos's Avatar
lol..jesse is a bad man...but even if its expensive, but could be done...what engine could be combined and be a beast...like a 9krpm v8 made by the s2000 engines..lol...
im sure theres some engines out there...doesnt vw have a w16 made from 2 v8's???
GTA4
Forza 4
Madden 12
Old Jan 13, 2006 | 09:11 AM
OniS14's Avatar
do it BIG!!
V8 honda race motor, eh?
Mugen MF408S Specifications
Layout:90° V8
Displacement:4000 cc
Horsepower:590+ hp @ 9500 rpm
Torque:383 lb-ft. @ 7500 rpm
Restrictor:33.4mm(2) or 46.8mm(1)
Clutch:Carbon, 5.5", 4-plate
Length:559 mm (not including fly wheel)
Width:720 mm
Height:577 mm
Crank height:92 mm
Weight:131 Kg
motor was used on the Dome S101..
additional info:
http://vtec.net/news/news-item?news_item_id=319284
what i want to see is a SR40VE...or a SR32VE...RB52DETTTT
S14 parts f/s
STANZZZZZZZZZZZZZZAAAAAAAAAAAHHH
Old Jan 13, 2006 | 09:19 AM
Troux's Avatar
You would be better off trying to configure a twin motor car to work. An engine is designed to operate at whatever layout it is. A 2JZ was designed to be a turbocharged I6, and would not produce the greatest results if mated to another bank of cylinders,even if it was possible.
