DIY Boost Controllers
good writeups!
I make MBCs using a natural gas valve from Home Depot. they're about $30 total, $20 alone in the big valve, but much easier to use and more pleasant looking.
ill snap some pics later of the one on my brother's car. i still have a profec type s buti m ditching it in favor of a larger wastegate spring and an mbc since ill only need it to jump about 2-3 psi over wastegate pressure and dont need the high low, since i prett much run 15psi daily.
pen from spring.........i bet it will....you get a small block of metal drill a hole in the top and side, thread it witha tap set, put two nipples in it, a spring and a ball......NOW THE HARD PART IS getting a hold of the drill press, tap and die set.
Srqspeed.com
-Dane
98 240 w/ bolt-onsSrqspeed.com
Joe P. FTW!
I bought an eBay one for $15 shipped...you guys are all sorts of lazy! You might as well shim your wastegate!
ASE: Brakes
ASE: Brakes
I know
I think ill spend more gas money going to homedepot to get the parts.
I got a set of tap & dies & drill press.
I will be done with it sometime tomorrow.
I think ill spend more gas money going to homedepot to get the parts.I got a set of tap & dies & drill press.
Originally Posted by ImportLuv
I think im gona go with that MBC method that Jordan posted. It looks more "professional."
Definitly, the 1st method is the cheapest that one can make, it doesnt get any easier than that. But as far as looks, i would have to go with the MBC.
Jordan, you get a cookie too for your post.
Profec II +1
7! pints of ale out the window sill
when I get my fill I'm chilly chill
