To much offset?
Well on first gen 7s,we have screw in style wheel stud/bolts like BMW/Porches.. I had my screw in studs,where you can run normal wheel lugs for a while,so today i decided to put them in,and try these wheels I got.
I dont kn ow the offset on the wheels,but they are 13x7,stock is 13x5.Id like to keep the wheel sin the fenders,but its actually sticking out about an inch from the top of the fender.
Does this look retarded?
I should of took pics,maybe ill do it tomorrow.
put some wide fenders on and you're set!
Originally Posted by John
pics would help, but you may be able to make it work with some camber
Do your wheels stick past the fenders some?
Originally Posted by Rotary7
solid rear end in the back,so no go on camber.
I was thinking of it,till I saw a 300-400$ price on 4 flares.
Guest
Posts: n/a
j35u5, 200 f0|2 4 pull? 7h475 p|2377y p|21c3y, 1 d0 17 f0|2 4 l07 l355
45 f0|2 my \^/h33l5, 7h3y 4|23 p|2377y much flu5h \^/17h 7h3 f3|\|d3|25, bu7 1 d0 h4v3 4 27mm pull 0|\| 17. My 5p3c5 0|\| \^/h33l5 4|23 18><9 +10 4|\|d 18><10 +11
jesus, 200 for a pull? Thats pretty pricey, I do it for a lot less
as for my wheels, they are pretty much flush with the fenders, but I do have a 27mm pull on it. My specs on wheels are 18x9 +10 and 18x10 +11
What is used in this process.
STANZZZZZZZZZZZZZZAAAAAAAAAAAHHH
[xbox360]DETrimentS14[/xbox360]
