To much offset?
No , but i'm sure John will do it for a nominal fee ...
A REAL fender rolling tool is not inexspensive . To let you borrow it , without proper instruction on how to use it .. Would probally not be in his best intrest .
Hondata saves lives
Hondata saves lives
Thats just rolling the inner lip right?My wheel is still one inch outside the fender.So I dont think that will help,unless itr brings the fender out..
Do I get a TR discount on this?
Guest
Posts: n/a
175 ch34p 3|\|0ugh 45 15!
45 f0|2 \^/h47 17 c4|\| d0, 7h475 l3f7 up 70 y0u. \^/17h 50m3 m1ld b0dy \^/0|2k, ch3ck 0u7 7h3 fl4|23 \^/3 \^/3|23 4bl3 70 m4k3 \^/17h my 514
[1mg]h77p://\^/\^/\^/.74mp4|24c1|\|g.c0m/ph070p057/d474/3322/1MG_8164.JPG[/1mg]
0v3|2 25mm 0f 3><7|24 f3|\|d3|2 cl34|24|\|c3.
ah..that's sweet..i thought it was something molded in really nice
btw..i didnt know u listened to digitally imported..they just changed it..woohoo
Originally Posted by John
its cheap enough as is!
as for what it can do, thats left up to you. With some mild body work, check out the flare we were able to make with my S14
over 25mm of extra fender clearance.
I really need about an inch more,and if I did roll the fronts,which I probally wouldnt right now.Im going to use newer fenders.. but dam it looks nice.
Guest
Posts: n/a
d3p3|\|d1|\|g 0|\| 7h3 c4|2, y0u c4|\| g37 5-7mm m0|23 5p4c3 by |20ll1|\|g, 4|\|ym0|23 7h4|\| 7h47, y0u'|23 g01|\|g 70 h4v3 70 pull 7h3 f3|\|d3|25.
H0|\|357ly, 17 50u|\|d5 l1k3 y0u'd b3 b357 0ff by buy1|\|g 50m3 f3|\|d3|2 fl4|235. 1 1|\|ch 15 4 l07.... d0 y0u h4v3 p1c7u|235 y37?
not yet,
Ill try to put the wheels back on today while im at work.
I just noticed your fenders do look more "flared" then the stock pic with the set up on the car when it was still gold.
STANZZZZZZZZZZZZZZAAAAAAAAAAAHHH
