Return of the Eclipse GSX?? with a 4g63?
Old Nov 3, 2005 | 07:13 PM
  #61 (permalink)
Jordan Y.'s Avatar
15 seconds EXHILARATION
Originally Posted by Cossack
superchragers put less strain on the engine becuase their isnt a quick jump in hp to the wheels.
Superchargers put more strain on the engine because to make the same WHP the engine has to put out a much higher output before the massive parasitic loss of driving the supercharger is factored in. A centrifugal blower may put less strain on an engine than a turbo kit by virtue of running low boost through peak torque range and ramping up boost as revs rise, keeping torque closer to a straight line, but you can do the same thing with a turbo kit and a good boost controller. It's the difference between 2 pounds at 3500 rpm and 10 pounds at 6000 and the full 10 pounds from 3500 to 6000 that makes a turbocharger "harder" on an engine, if anything. That also means more power in the form of torque through the rev range, though.
