n2o or propane?
Old Sep 2, 2005 | 05:47 AM
Sneakin Deacon's Avatar
PSSHHH x2
people probably dont like it because its flammable...nitrous isnt.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 2, 2005 | 06:10 AM
DrDirt's Avatar
Team Geritol Racing
Propane gives you slightly less cooling effect and oomph than the n2o but as Kenny said, it is a fuel. It has an octane rating of somewhere in the 118 range IIRC. Of course, you're not using that much if you're spraying propane but still, every little bit helps. It's cheap and you can get it almost anywhere. You have to have a bottle setup though where you can extract it from the bottom and not the top so that it is in liquid form in your lines. I looked into it a few years ago as a small shot to spray on top of my blower, mostly for the cooling effect. I never got around to doing it but overall, I think it would have more pros than cons.
YO! Barry! You LOST!
Old Sep 2, 2005 | 08:01 AM
SkwervE's Avatar
realer than most
so would propane work better than nitrous? or more complications?
Old Sep 2, 2005 | 09:45 AM
F*r*a*n*k*e*i's Avatar
I say go with hydrogen. That should really get those pistons moving.
Old Sep 2, 2005 | 09:48 AM
PSSHHH x2
should just get away from using gasoline and do what the space shuttle does...straight hydrogen and straight oxygen introduced at a rapid rate...0-15000...1 minute.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 2, 2005 | 09:49 AM
Jeff'sSS's Avatar
dy-no-might
Originally Posted by Sneakin Deacon
nitrous is "air", propane is fuel
werd
Torch Red SS 6 speed
Euro Red MR2-T 5 speed
2000 Si FS $3000 buy me! buy me! buy me!
  #17 (permalink)
JonLGT's Avatar
Just for decoration
I thought propane was only used in diesel engines.
Old Sep 2, 2005 | 09:50 AM
  #18 (permalink)
ImportLuv's Avatar
Propane all the way.
there was even a episode on Trucks where they installed a propane kit on a truck.
Old Sep 2, 2005 | 10:16 AM
  #19 (permalink)
PSSHHH x2
not exclusively. it gives added octane dependant on amount sprayed...and the best thing about it, it doesnt puddle. like i said, its like a wet shot in itself. grand national/tta guys are using it aswell.
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 2, 2005 | 11:58 AM
  #20 (permalink)
Road Rage's Avatar
Shake n' Bake
yea it is, havent you seen F&F!!!!
