Need some headlight help...
Originally Posted by corey r.
I dont think thats the same thing as the headlight assembly for a tiburon.
My Tempo, after 10 years, had perfect lenses. After we put 40,000 miles on top of the 10,000 it had, the lenses were starting to yellow.
How many miles on the Tiburon?
Better stock up on whatever does work if every 2 years you have to re-clean them.
Meanwhile, I am considering the $20 each headlights that are supposed to be much brighter, because I can drive with my high beams on and nobody flashes at me...makes me think they're not too bright. And I can hardly see far enough on a dark wet road.My understanding anyways was that it was inside, not outside. But hey, scrub away.
They vary from car to car. Not all makes of the same car will have this problem. But the majority of the discoloration takes place on the outside for most lenses, the inside will have the same problem, but most of the time its not nearly as bad.
SUCH IS THE RULE OF HONOUR.
orbital buffer and some toothpaste.
"The genius of any slave system is found in the dynamics which isolate slaves from each other, obscure the reality of a common condition, and make united rebellion against the oppressor inconceivable." ~Andrea Dworkin
"If... the machine of government... is of such a nature that it requires you to be the agent of injustice to another, then, I say, break the law." ~Henry David Thoreau, 1849
That's right, bitches, TWO quotes!
