Cork Oil Pan Gasket Question
Old Apr 25, 2005 | 11:03 AM
  #21 (permalink)
BigBadBuick's Avatar
Livin' Large
Originally Posted by buck19
the factory oil pan gasket for this motor is just straight RTV. did that and it had a leak, and it takes forever to scrape it clean and reapply gasket. so just got a cork gasket.
What kind of RTV? Like I mentioned earlier, the "grey import gasket maker" they have at places like advance works great. I recently did a tranny service on a neon (Sweet!!), put the rubber gasket in that came with the filter, next morning there was a lake of tranny fluid under it. Pulled the pan again, tossed the gasket, ran a bead of the GIGM around it, let it sit about ten minutes to skin over, put it together and never had another problem.
Old Apr 25, 2005 | 11:26 AM
  #22 (permalink)
osama tim laden's Avatar
kings cannot fall.
i use the spray disc brake quiet to hold the gasket in place, and then use permatex form a gasket, or "the right stuff" on top of that.
but if this is for a ka, i dont reccomend using the gasket at all. unless you want it to leak.
Old Apr 25, 2005 | 03:13 PM
  #23 (permalink)
0HP930's Avatar
Guest
+1 on using a small amount of sealant on cork gaskets.
I love some of the new cars that use a hard plastic spacer with an o-ring like rubber seal in it. Those things work damn well with no sealant at all.
Old Apr 26, 2005 | 11:17 AM
  #25 (permalink)
flubyux2's Avatar
Elitist Supra Asshole :)
yes, cork doesnt like heat at all...
i used several strategically placed dabs of Gray RTV to hold the gasket in place while i positioned the parts. there is one part that had the surface gouged a few times, so i put a skim coat of silicone on it to fill in the imperfections and then applied the gasket.
wire brush/wheel on a drill works wonders for removing gaskets and silicone.
fadedSTi
Apr 28, 2004 11:10 AM
Cronic
Nov 7, 2003 03:04 PM
100whplusperliter
Sep 19, 2003 03:51 AM
