Who thinks they understand the difference between Tq and horsepower....
Old Apr 22, 2005 | 04:47 PM
  #61 (permalink)
NegativeGeForce's Avatar
3 liters is the limit in f1 cars...there are f1 engines these days as small as 1.8 liters turning 20 grand....
lets say an f1 car makes peak torque at 10k rpm and stays consistant to 20k rpm...yet the horsepower is tripple of the torque at 20k rpm.
the fucking car is gonna accelerate alot more at 20 grand then 10 dude....
horsepower is how fast the torque is being used.
TORQUE IS A FUCKING DEAD WEIGHT...HORSEPOWER MOVES IT!
max accleration isnt defined by torque or horespower, but maximum power wich depends on the torque and hp curves...thats why it is important to know both numbers!
Old Apr 22, 2005 | 04:48 PM
  #62 (permalink)
HybridSS's Avatar
I have fuzzy eyebrows
Originally Posted by shadowboy
peak acceleration at any given speed is where power is maximized. period. empirical rule. bar none, no arguments. if you disagree, i can prove why you are wrong.
You seem to be contradicting yourself a bit.
First you agreed MAx accel occurs at peak Tq....in a given gear. But then make the statement above. I would make the same statement...but put the term Tq in place of power.
Of course all this discussion will not take into account wind drag, rolling resistance etc.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
  #63 (permalink)
power2weight's Avatar
-eats the last cookie.
hybridSS:
in the case of first gear:
at the torque peak in first gear there is NO gear selection that will give you more power. go beyond that and your acceleration DOES slow, but that's only because there's still no example of a gear where you have more power than first gear.
i NEVER disputed the peak acceleration in a car overall would be at the torque peak in 1st gear. that' the ONLY time you will ge more acceleration from the torque peak than the power peak. in ALL OTHER GEARS if you drop a gear and make more power you WILL get more acceleration. period.
Power available never changes. You agreed upon that initially, and now are disputing it.
Did it occour to you that if you drop a gear, you gain mechanical advantage, and your torque increases?
"They must really feed each other to the lions down there........"
Old Apr 22, 2005 | 04:49 PM
  #64 (permalink)
shadowboy's Avatar
insert witty retort here
Originally Posted by Jordan Y.
I think we've all been saying the same thing, just in different terms.
which is precisely what i meant when i said we've been arguing semantics.
we just all conceptualize it different.
its obvious that everyone discussing understands the difference, otherwise there wouldn't be much of a discussion.
Shawn
The answer to your question is sqrt(pi)
Old Apr 22, 2005 | 04:50 PM
  #65 (permalink)
HybridSS's Avatar
Not trying to be confrontational...but this is all wrong
If Tq is the same from 10k to 20k...acceleration will be the same (minus wind resistnace and rolling resistance etc).
TQ is the only thing thats applied and used. HP has no application other than to show total work.
Old Apr 22, 2005 | 04:51 PM
  #66 (permalink)
shadowboy's Avatar
i never said power never changes. i said power is the limiting factor. big difference. at different rpms there is different available power. different gears = different rpm = different power.
Shawn
Old Apr 22, 2005 | 04:53 PM
  #67 (permalink)
shadowboy's Avatar
i agree with this response, in that if tq from 10k to 20k is flat, the acceleration will be the same all the way up--with a fixed gear ratio
Shawn
  #68 (permalink)
HybridSS's Avatar
Ahhh...I see what you are saying I think. But I would still substitute the term Tq in place of power.
Old Apr 22, 2005 | 04:54 PM
  #69 (permalink)
you so your telling me an f1 car will accelerate the same at 10k vs 20k? LOL!!! get in a fucking f1 car and goose it at 10k and 15k....
like i said...i am getting more stupid as i read
Old Apr 22, 2005 | 04:56 PM
  #70 (permalink)
HybridSS's Avatar
Thats what I am telling you...yes...exactly
