Who thinks they understand the difference between Tq and horsepower....
Old Apr 22, 2005 | 09:30 PM
  #91 (permalink)
Half Fast's Avatar
LT1's are slow!
Originally Posted by Half Fast
Give me a tall, flat torque curve and a wide rpm range. You can have the hp for dyno racing.
uhhhhh, yeah, what he said.
Old Apr 22, 2005 | 09:43 PM
  #92 (permalink)
Strokd85's Avatar
Daddy-O
Al, I have to give it to you for trying to explain it to him, but he's trying to include variables that don't apply, so he won't get it.
The way I look at it is this, on a dyno you don't make full pulls in all gears as you will not get a true reading (using that term loosely) as to the TQ and HP that your motor makes. You make a pull in a 1:1 gear (or whatever is the closest, in your respective vehicle).
With that being said, measuring your peak acceleration will be as easy to find as Al stated earlier (# of RPMS gained in set time frame), gearing won't have anything to do with it.
or I could be completely wrong, as I am tired...
I am your penalty.....
Old Apr 23, 2005 | 10:18 AM
  #94 (permalink)
Steve B's Avatar
brings his heater.
it changes the ratio that force is applied
Old Apr 23, 2005 | 02:03 PM
  #95 (permalink)
Dead Hooker's Avatar
Originally Posted by Maite
Since torque is the actual force applied, and horsepower is an equation to find our work perforrmed... it is quite obvious that the optimum excelleration does occur when the most force is applied, which we all know to be peak torque.
Here is another question: Why does changing the rear gear on a dynojet affect peak torque and peak horsepower?
Any takers?
This is a great question.
It takes energy to accelerate the short block (rotating assembly) of a motor. This is why a motor with lighter crank/rods/pistons will be faster than a motor with heavier parts...all else equal.
Everyone seems to agree that it takes more torque to produce a higher accelaration rate in a car and likewise, it takes more torque to provide a higher acceleration rate in the short block itself - before the drivetrain/car is ever introduced into the picture.
If you put a car on a chassis dyno with a 3.73 gear ratio, you will be able to plot the engine acceleration over time (like Al's example...rpm increase per second.) Let's say it's an average of 300 rpm's per second over the course of the pull. Now put the same car on the dyno with a 4.56 ratio and repeat. As you stated, it will be slightly different. Shouldn't be alot, but all else equal, the 4.56's will make slightly less torque at the tires. Why?
Plot the engine acceleration for the second pull (4.56's) the same way you did the first. It will be higher. Let's speculate a 350 rpm increase per second average. The engine accelerated faster during that second pull. And what did we say about accelerating the engine itself? It takes more torque to do it faster. Therefore, in the second dyno pull, more of the engine's total available torque at any given RPM was use to accelerate the short block rotating assembly itself and less was left over to accelerate the drivetrain.
Another example. When using an engine dyno, you can perform various different tests. Normally what you see on TV and stuff is a test where the engine is allowed by the water break to accelerate at a specified rate. Another popular but less known test is what is called a step test where the engine is actually held by the water break at stepped intervals - say every 200 RPMs. Guess which test almost always makes more torque/power? The step test. Why? Because during the step test, as the motor is being held and not allowed to accelerate, all of it's total available torque is applied against the break and none is being waisted in accelerating the bottom end assembly.
But we aren't talking huge differences here. The fact that a car may dyno a little less with a steeper gear ratio has no bearing on how it will run at the track.
One last thing along these lines. Think about how much a big block's rotating parts weigh in comparison to a small block and remember it takes torque to accelerate all those heavy parts!! (no offence to the big blockers here)
Sorry to deviate from the original subject matter....but she asked.
Old Apr 24, 2005 | 07:44 AM
  #96 (permalink)
25psi's Avatar
Treated and Released
I think I am starting to grasp the concept. TQ is the determining factor of max acceleration. I think gearing plays a BIG role in this whole thing that evens the playing field. Why will a car with 200hp and 100tq out accelerate a car with 100hp and 200tq? Why will professional drag racers put such a cam in their cars that it can barely idle, in the pursuit of high end HP. I don't think it is for high end TQ because you could still setup and engine with all the TQ in the world but it wouldn't have the same amount of HP as the HP-biased engine.
The way I think about it: TQ is how much weight someone can move, HP is how fast the can move that weight.
-Jim
“Equality, rightly understood as our founding fathers understood it, leads to liberty and to the emancipation of creative differences; wrongly understood, as it has been so tragically in our time, it leads first to conformity and then to despotism”-Barry Goldwater
Old Apr 24, 2005 | 08:12 AM
  #97 (permalink)
HybridSS's Avatar
I have fuzzy eyebrows
This concept of why you will actuall show LESS Tq at the rear wheels with a higher numerical ratio is even more mind boggling.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old Apr 24, 2005 | 08:29 AM
  #98 (permalink)
Charles's Avatar
Senior Member
OMG a quality automotive related thread on TR
92' Nissan 240sx
02' Honda VFR Interceptor
08' Tundra
Old Apr 24, 2005 | 11:35 AM
  #99 (permalink)
SickOfAlltezzas's Avatar
ALUMINUM POLISHER
1.Horsepower sells cars
2.Torque wins races (real races,not rolls)
Originally Posted by 240Cyanide
TR's better anyways.. where else could you find all this variety of assholes, drug specialist, and pedo's? not on that gay dsm site!
Old Apr 24, 2005 | 12:57 PM
  #100 (permalink)
Rolling Thundah's Avatar
This rare occasion is much like an eclipse(not the car) happens once in a great while!
