milling?
Old Apr 7, 2005 | 01:02 PM
GsEclipse02's Avatar
Default milling?
not sure if thats the way you spell it but o well....
heres the story i let a local shop work on my car and they put my manifold on wrong they had it sitting on top of the thermostats and i drove on it for a few days .... now im having another shop try to fix all the problems the 1st 1 has created my manifold is now warped like you wouldn’t believe ... so were is the closest milling shop near Sheldon and waters thanks in advance people.
Old Apr 7, 2005 | 01:58 PM
Whaazup17's Avatar
so you want it machined?
Old Apr 7, 2005 | 02:15 PM
Illswyn's Avatar
Is the 1st shop paying for the damages, or do you just not want them to touch the car again?
Old Apr 7, 2005 | 02:54 PM
gsrturbo4's Avatar
Turbo 4V 92 Coupe
i dont understand how you can put a manifold on wrong the header bolts wouldnt line up if it was. sounds to me like it didnt fit properly in the first place.
Old Apr 7, 2005 | 03:49 PM
Whaazup17's Avatar
a fly cutter can clean that up really good. I did a turbo manifold one time. It was just two inlet holes.
Old Apr 7, 2005 | 05:09 PM
i think so .... im not sure they said it was called milling ... I just need it to be flat you know....
the manifold wasn’t cut right on 1 of the corners of the manifold and when the 1st shop put the manifold on it was obvious that it needed to be trimmed up some ...
Old Apr 7, 2005 | 05:58 PM
SloCxHatch's Avatar
No "V-TECH" here!!!
machine, planeing, or milling he needs it shaved down so it will be a perfectly flat surface so it will bolt up to the head flush
You can find me at the Track!
KJ built
ALPHA TUNED
Induction Performance 727.505.1423
* Engine Management Tuning, Track Setup, Consultation, Turbo Sales, Parts Sales (WorldWide)
ONLY SHOP IN TAMPA THAT TREATS YOUR CAR AS THEIR OWN
ding ding dong
Old Apr 7, 2005 | 06:05 PM
TIM TIM TIM's Avatar
could be worse
Yeah the manifold needed to be trimmed a little bit, the gap between the block and manifold was about 3/8's of an inch, it was pretty obvious that it wasnt right. but owell, the only place he knows of is off fletcher somewhere, are there closer ones to waters and sheldon?
aim:because tim said
Old Apr 7, 2005 | 06:35 PM
Whaazup17's Avatar
yea milling would definitly be the way to do it. It isn't that hard to mill it. The problem that you would face that would be the most difficult is how to mount it. From what I thinking it is a 4 cylinder manifold so it has some funky twists in it and everything. That is the problem you would have. The cutting is not difficult.
and if you get it done by a machine shop make sure they prove to you with a dial test indicator it is flat say within .001"
