well, two headgaskets down.....
30+ psi and no blown headgasket here. OEM gasket too.
stock ls is 9:1 190 psi im sure ur running NA
Hmmmmm leakdown test. I know the ghetto way to do it, but how to do the original way, i am not sure of.....info?
Guest
Posts: n/a
Originally Posted by s10_male
My headgasket was crack on my neon- drove it like that for over 5k miles then I just traded it in.. There was no coolant in the oil- just oil in the coolant.
Originally Posted by SupraKid
most retarded thing I ever read......................dont say that again
Sucks to blow a headgasket. Pain in the ass to replace.
Mazda 2 Forums
R.I.P. Pablo 'Fathead' Garcia - Love you man! See you on the other side!
R.I.P. Kevin 'Slo_Si' Gonzalez - You will be missed!
Mazda 2 Forums
Guest
Posts: n/a
45 l0|\|g 45 7h3 57up1d 1|\|74k3 m4|\|1f0ld 5upp0|27 b|24ck37 15|\|'7 7h3|23, 1 c4|\| pull 4 h34d f|20m 4 d0hc h0|\|d4 1|\| 4|\| h0u|2 0|2 l355. C'm0|\| m4|\|, 17 41|\|'7 7h47 h4|2d, 1'm 7h3 5l0\^/357 m3ch4|\|1c 3V3|2.
4f73|2 y0u pull 17, 1 \^/0uld (1f y0u h4v3 |\|07 4l|234dy) pu7 1|\| 4|2P 57ud5, h4v3 7h3 h34d 73573d 47 4 m4ch1|\|3 5h0p f0|2 b31|\|g 57|241gh7. Y0u 5h0uld|\|7 b3 p0pp1|\|g h34d g45k375 l1k3 7h15, 50m37h1|\|g 15 |\|07 |21gh7.
well, i overheated pretty bad last week, i think thats when i did it...the head is perfect , i had it resurfaced at NATIONAL CYL HEAD....the HG was copper sprayed...The Intake mani bracket is gone...need ARP studs and OEM gasket...
