well, two headgaskets down.....
Originally Posted by clips92
ok too any one who has a eclipse<1.8 ohc can i take the top end of A 1.8 dohcand put it on my block
will it all bolt up to my 1.8 ohc
thanks ,clips1.8
thanks ,clips1.8
I have white smoke every once and a while....is this because when the thermo opens to let coolant in, it then burns it? At idle it doesn't smoke sometimes....
I think i overheated b/c i had to take out my radiator fan to fit the filter for the turbo....today i routed the radiator fan wiring to the a/c fan. Works great. So hopefully i wont overheat anymore.....
GAWD HEADGASKETS SUCK TO REPLACE!
Originally Posted by SupraKid
weld your head and block together, problem solved
Originally Posted by 94lsTEG
Dont highjack threads! ....read the NOOB forum b4 posting!
It means your HG is perfectly fine...
