some pic's of my engine build
Old Feb 26, 2005 | 02:39 PM
74javelin's Avatar
Default some pic's of my engine build
i when over to my friends house today and we put some of my motor together. the rockers still need to get ajusted and we just put the intake and valve covers on to take a pic. those are not my valve covers. here's some pic's
Old Feb 26, 2005 | 03:51 PM
Rdline1's Avatar
Hi Hi Hi?
cool, what kinda power are you expecting?
98 Camry w00t! (daily ride)
91' Eclipse GS-t (she's alive!!)
AOL IM: usfbull49
Originally Posted by Frankie
When a jelly fish comes out of my ass, I'll take pics.
Old Feb 26, 2005 | 04:13 PM
74javelin's Avatar
i'm hoping 500/500 at the crank. power range is 2600-6200 and i've got a 3200 ati 10 inch stall so i'll be running 3200-6000-6200. if i don't make 400hp at the wheels with this small cam. i might put a little bigger cam in next year.
Old Feb 26, 2005 | 07:39 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
Cool. When are you expecting to have the car on the road?
Old Feb 26, 2005 | 08:19 PM
JonLGT's Avatar
Just for decoration
You need heatwrap
74javelin's Avatar
the car is still up and running.
i still have to pull the engine, paint the engine compartment, put in a new crossmember, new front springs, a stock cowl hood so the motor will fit under the hood, i need a few things welded onto the intake. i hope 4 to 8 weeks.
Old Feb 26, 2005 | 08:41 PM
jdk's Avatar
jdk
Non ducor, duco
+1 on the heat wrap. Make sure to do the manifolds all the way to your mufflers, and the intake from the filter all the way to your throttle body.
Old Feb 26, 2005 | 08:57 PM
74javelin's Avatar
my headers are jet-hot coated and i'm running a carb with a cowl induction hood. i just hope i can get the cowl induction setup to work with that intake.
Old Feb 27, 2005 | 12:23 AM
LS1Fever's Avatar
what size motor is that? what are some of the parts you running with? are you doing a solid lifter/roller lifter setup? what cam are you using and carberator? just curious because you not expecting too much from it.
Old Feb 27, 2005 | 09:49 AM
74javelin's Avatar
401 amc sb
indy heads flow 320@ .700 lift 290@.500 lift
10.7 to 1 35 quench
stock forged rods and crank
750 holley vacuum secondaries i might go 800/850 dp down the line.
small HYD roller 224/232 543/564 lift. this is why i'm not expecting much from this motor. but should drive really nice on the street. the cam is really too small for the heads and intake. i might put a torker on it and see if my 1/4 times go up.
the reason for the over kill on the heads is because i didn't want to put money into a set of heads and then down the line have to get a better set for more HP.
i was going to use a 234/242 565/584 lift cam. but it's a 45+ minute drive to tampa and 2 hours to a 1/4 track. with the small cam i can drive it all the time. my stall is a tight 3200 10 inch. with the bigger cam ati said i should use a 4000 8 inch stall.
i just need to change the cam if i want more power. a full port job on the heads and they flow 344 @ .600 lift and 350@ .700 lift
destop dyno 2003 said 560/500 but i don't believe it
dyno 2000 said 512/500
when i ordered my stall the guy at ati said ( it's goting to make 500 LBS of torque )
as you know, it's all in the combo and my motor is setup for a big cam. i'm a little worried about the small cam. but i'll see how it works. as long as i can pull high 11's or low 12's i'll be happy for now.
