oil filter cutter
Old Jan 26, 2005 | 11:29 AM
Whaazup17's Avatar
Default oil filter cutter
Does anybody have one? How does it work. I seen one in the longacre catalog. I was thinking I could make one though but not to sure how it works actually.
Old Jan 26, 2005 | 11:42 AM
TNathe's Avatar
What is an oil filter cutter? I mean why would you cut an oil filter? I don't see the reasoning.
Old Jan 26, 2005 | 11:46 AM
Whaazup17's Avatar
to check if you have any metal chips or shavings in the filter. If they got into the filter they are in the oil if they got into the oil they fell off a crank,rod, bearing, piston or something.
Old Jan 26, 2005 | 11:50 AM
s10_male's Avatar
s10_male
hack saw it at the towards the seal- it then metal won't take long
Old Jan 26, 2005 | 11:51 AM
The Kyle's Avatar
Captain Catastrophe
QUASTION
Old Jan 26, 2005 | 11:56 AM
Whaazup17's Avatar
right down the middle? I am trying to figure out how this tool works on cutting it
Old Jan 26, 2005 | 11:57 AM
Whaazup17's Avatar
I think you set the filter in the middle and the two bolts and nuts hold it. Then you crank down on the knurled screw and the cutter cuts the filter and then you swivel it around the filter
Old Jan 26, 2005 | 11:58 AM
Road Rage's Avatar
Shake n' Bake
it works like a can opener.....
Carlos's Avatar
**International Baller**
we speak english here
if you use a hacksaw, metal will get in from cutting. You sure you dont have junk cars in front of your house
Whaazup17's Avatar
I get it now. I am going to try and make one.
anybody wnat one
