Question on a DIY intercooler sprayer.
Old Dec 28, 2004 | 06:47 AM
Ian MMF's Avatar
Omnipotence
Originally posted by Jordan Y.
That's pretty much what I've read, but on the flip side, it's nearly free. I figure it's worth a shot on my stock sidemount, which might actually get hot enough to get some heat carried off it before the beads of water/ alcohol get blown off. On the front mount, I may not bother.
I did wonder about the track issue. Do you think a fine mist on the IC could leave enough residue behind to be dangerous on the last half of the track? I was planning on pushing the button to turn it on shifting into third so it would be working through third and fourth, I was worried about that very problem at low speed, leaving water behind.
Would it be unsafe for others to spray it when already travelling at 60+ mph? I think it would just disperse, but if any of you high hp slick tired rwd guys would have a problem with something like that, please chime in so I don't cause a problem.
I know most cars at the track once they hit ~1000' mark the last thing they want is to hit a mist of water on the track. Ever see a car get lose up top and wonder why. Water is just as dangerous as oil when it comes to up top at the track.
Also when spraying meth, ever notice why at big events if their are jet cars they run at the very end? The fuel leaves a film on the track that isn't racer friendly.
Old Dec 29, 2004 | 03:02 PM
Gerald's Avatar
Don't waste your money....
If you want to cool your charge think about some water injection or a ***small**** shot of nitrous to cool your intake.....
Gerald
98 Dodge Viper
05 Dodge Viper
Old Dec 29, 2004 | 03:44 PM
Sneakin Deacon's Avatar
PSSHHH x2
nitrous would only do more harm than good. if your on the verge of detonation, last thing you wanna do is add more air and no fuel. basically if you take the EGT's of a NA motor on nitrous, yea it will cool that intake charge, but those EGT's will be noticeably higher, indicating high cylinder temps.Razor's kits are probably the most advanced ive seen around. being able to use alcohol, or methanol is good, because your actually cooling the charge down, and adding fuel.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
