If building a car was artwork, IMO this is a masterpiece...
Originally posted by 4drwhore
And Yes I am talking about traction in the state of drag racing, not roadcourse racing or auto-x or anything else.
I doubt the original person asking has any intentions of making a trailered drag car or assembling a second set of drag-specific wheels with huge flexing sidewalls.
"15" is the best for traction"
Let me finish it for you,
"...for launching in a straight line, when combined with a proper tire, and it will be a piece of floaty crap to drive around any corner in a spirited way."
You didn't even ask the dude what his intended use was.
Orion ZyGarian, if you want more traction from a well-rounded street car, daily driver, autocross car, or road race car that a) you're not trying to break into the 11s with and b) will retain the stock rolling diameter so that your speedometer and mileage counter are not affected, go with the lightest wheels you can find in a size that is 1" bigger than stock and buy appropriate tires to keep the rolling diameter the same as the stock setup. As you feel necessary, add an inch to the width if you can fit them into your wheel wells. And remember that the weight of your tires is FAR more important to consider than the weight of your rims for acceleration purposes, since the weight is the farthest from the center of the wheel (it has the most inertia).
Impressive kickslop. I should have been more clear with my initial statement. And yes I would agree with what you said about wheel size to chose.
BTW - Don't all of nascar, formula one and most road circuit cars also use 15" rims?
Formula 1 and NASCAR wheels are under strict regulation restrictions.
Examine any similar racing type without those restrictions, or greatly inflated "max size" restrictions. There's a reason almost every WRC car runs 18" wheels on tarmac rallys
http://216.117.199.231/Toyota-JGTC/Toyota-JGTC-019.jpg
http://www.coronel.nl/tom/picture/20...C/tc03gt67.jpg
http://www.geocities.jp/hide5635/pho...cfinal.115.jpg
http://www2.rallysport.info/forum/flash2000165.jpg
http://www.rallyplanet.com/media/pho...c03_tarmac.jpg
I have toned down alot. I just like trying to see how much I can get out of people. Alot of people have good knowledge but when you try to pry it out by telling them they are wrong sometimes they flip out.
BTW Nice pictures from JGTC
Dammit..so I was 'right' the first time with the 17" Kosei K1 TS?
I just figured the tread would matter more than the weight...I had 'planned' Kosei's all around, BFGoodrich g-Force T/As in front and g-Force T/A Drag radials in back. I doubt I'll see 11s in this project. Most of it would be highway/interstate performance (read performance, not races) and also for drag racing at BMP. Eventually, once or twice I wouldnt mind trying out an auto x just to experiment, but I never know where they are or anything
Also, I've heard of filling up the tire with nitrogen instead...the K1 TS rim has dual purge valve things for it...what do you know about the subject?
ASE: Brakes
ASE: Brakes
(turns around and runs away)
Originally posted by Tire Rack.com
¤ Dual valve stems facilitate the use of the less heat sensitive gas nitrogen for racing applications
Originally posted by Kosei website, roughly translated
The user which fills up the nitrogen gas in the tire recently, in place of the air has increased, but that comparing & fluctuating of the internal pressure is little in the air, * the gas to come out becomes difficult improving of fuel economy, because there is a merit that * because it is not included life of the tire and the wheel extends, because * than the air the vibration is more difficult to be transmitted, riding comfort to become good the road noise due to air resonance decreases the impurity, is. While with motor sport as for nitrogen use to be standard, pulling out the air, it fills up nitrogen, it installs 2 air valves in order higher efficiency to raise nitrogen density at a to a greater extent. Competition standard... "K-1 racing TS version" adopts the twin valve to many people of course, 貫 pulls out development theme.
ASE: Brakes
ASE: Brakes
