Solid Motor Mounts
Old Nov 7, 2004 | 12:51 PM
TheShow50h's Avatar
The little 5.0 that could
Originally posted by 351coupe
Solid all the way!!Ofcorse mine isn't a daliy driver.
That's the problem. I drive this car just about everyday.
I can get a pair of new moroso solid mounts for $30 or some ES poly mounts for $120. I want to make sure that solid wouldn't be too bad, but it seems as though they are.
-Vince
Old Nov 7, 2004 | 01:15 PM
TheShow50h's Avatar
Originally posted by Mars_302
Poly mounts and make sure to get a alumn d/s you are gonan get so much more driveline vibration with those mounts.
Maybe I should just get stock replacements? Or maybe ones from a 93 vert?
-Vince
Old Nov 7, 2004 | 09:31 PM
Hulk's Avatar
Solid you run risk of damaging your tranny. Would go with poly, you restrick the movement, but still retain some vibration, but not as much as the solid. I had a friend blow his torque converter after going solid.
Hulk get MAAAD!!!!!!
Old Nov 8, 2004 | 03:09 AM
Boostin97SE-R's Avatar
Resident Asshole
i can guarantee you his torque converter going had absolutely nothing to do with the solid mounts.
I had the es kit in my 200sx. While it was no v8 with a lopey cam, I could still feel more vibrations in the car. Throttle response was now unbelievable and instant. I got used to the vibration as it was not too bad and most people who rode in my car never noticed the extra vibration. so i liked my es kit.
Old Nov 8, 2004 | 03:11 AM
Resident Asshole
one more thing i forgot to add, You can make your own solid mounts by using the stockers and filling them with window weld from discount autoparts. Just get a spare set of oe motor mounts and make your own and see if its bearable to you. the window weld will be a little stronger than the es kit if i remember correctly.
Old Nov 8, 2004 | 07:17 AM
  #17 (permalink)
BigBadBuick's Avatar
Livin' Large
I never had bad vibration with solid motor mounts. Once I put in a solid tranny mount, I couldn't see anything in my rear view mirror I have been told (never, ever seen it, so no arguing ) that you can actually break the mounting point off your block using solid mounts, but like I said, I ran them with zero problems. Eventually I went to convertible motor mounts with a stock tranny mount and it was smooooooooth
Old Nov 8, 2004 | 11:45 AM
  #18 (permalink)
psifactor's Avatar
Hello
Originally posted by `92CXhatch
cons, you will find something else to brake, your car will shake like a bitch and you will hate it...
keith..come on now... I'll take you for a ride and you would NEVER know I have solid motor mounts. ahh, the joys of a smooth engine
Heavy car with a 2.5L
Old Nov 8, 2004 | 02:44 PM
  #19 (permalink)
TheShow50h's Avatar
That's the plan now .. 93 vert mounts and stock tranny mounts.
-Vince
Old Nov 8, 2004 | 02:45 PM
  #20 (permalink)
TheShow50h's Avatar
.500/.500 236/248@.050 .. Smooth wasn't the goal of this cam.
-Vince
