stroker kits
Old Sep 25, 2004 | 11:41 AM
type-j-spec's Avatar
Default stroker kits
i heard your engine wont last long and they are the "devil"
but id like to hear some opinons on em,seems like most people steer clear of them.
are they even worth it?
Old Sep 25, 2004 | 02:19 PM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
I dont know myself...but I know you can put a 4G64 shortblock with a 4G63 head and have a DOHC 4G63 w/2.4L. Dont know what problems may come, nor if you'd really call it a "stroker kit"..
It also would probably depend on what engine it would be done to. I assume a 95 Integra
Maybe Honda Tech will know
ASE: Brakes
Old Sep 25, 2004 | 02:49 PM
TheShow50h's Avatar
The little 5.0 that could
I know they are worth it in my world. Does wonders for low end power with a big stroker kit.
-Vince
Old Sep 25, 2004 | 03:04 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
It depends on the application. Ask in Honda Tech.
Old Sep 25, 2004 | 03:24 PM
0HP930's Avatar
Guest
The only downside is that they often require a lot of block mods so the overstroked parts dont hit anything.
For example, right now our shop is building up a lingenfelter 427 small block kit for a vette. Lets just say that I had to do a lot of machining to fit 427 cubes into a small block. Even the pan rails had to be notched to clear the rods
The problem with it now is that the rods are hitting the cam lobes. Since we really cant grind away on either we are hoping that either a reduced base circle or less radical cam will solve that problem.
Old Sep 25, 2004 | 03:42 PM
i meant kits in general
Old Sep 25, 2004 | 03:54 PM
Josh's Avatar
Dr. Doom
not really worth it on honda's man, you're better off getting oversized pistons, that will increase tq quite a bit.
Old Sep 25, 2004 | 08:00 PM
jdk's Avatar
jdk
Non ducor, duco
Oh come on, this is all the space you need between cylinders
Old Sep 26, 2004 | 01:23 AM
Sneakin Deacon's Avatar
PSSHHH x2
little bit more to it then just slapping the head on the block..
and for a honda i dunno how much it would really help, i know on my car, going from a 350 to 383, id pick up like a good 100rwhp..of course, thatd be low comp pistons, forged bottom end, crazy cam, and more boost.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 26, 2004 | 06:14 AM
Like I said, I dont know myself, and it does vary. I believe bolting a 2JZ shortblock to a 1JZ head is all it takes though. 2.5 --> 3.0
ASE: Brakes
