Nitrous Intercooler Sprayer
Old Sep 22, 2004 | 08:40 AM
  #21 (permalink)
The Spectacle's Avatar
Spent more money than you
Originally posted by 4drwhore
Who said anything about at TT?
Originally posted by Zate
those things are a gimmick and a waste of money right up there with turbo timers.
i wanna know too...why are TT a waste of money?
Racing Integration
LHT Performance
My tuner is named Alpha
Old Sep 22, 2004 | 08:45 AM
  #22 (permalink)
Ian MMF's Avatar
Omnipotence
Gotcha, didn't see it.
Old Sep 22, 2004 | 09:16 AM
  #24 (permalink)
Ian MMF's Avatar
Omnipotence
nice post!
Old Sep 22, 2004 | 09:17 AM
  #25 (permalink)
Tripw0l's Avatar
The thirst mutilator
so what's the benefit of mixing the water with the alcohol? does it increase the heat exchange property or is it to keep the water clean and keep the mister from being clogged with algae?
(just curious)
"If I could write off your murder
I'd save all of my receipts
because I'd rather you be dead
than lose a tiny shred of what I made this fiscal year"
-Nathan Explosion (Brendon Small)
Old Sep 22, 2004 | 09:25 AM
  #26 (permalink)
Gary's Avatar
eh
(just curious)
I don't know for sure, but I would imagine the evaporation properties of alcohol would improve the phase change of water as Zate explained.
AIM gwhIIx
Old Sep 22, 2004 | 12:11 PM
  #27 (permalink)
Acidtalons's Avatar
(just curious)
Alcohol phase changes even easier than water, but you can't run just alcohol cause it would evaporate in the reservoir. Also the Alcohol most likely acts as a detergent to break up the water molecules into smaller groups and then they will more easily absorb heat.
Vehicle Repair/Maintenance and TIG welding services for hire (steel and Aluminium), PM or IM me
AIM: Acidtalons
  #28 (permalink)
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
nice post!
Holy crap :o +3452345
Thanks for the info. Now I know to get a mister instead of a "sprayer". I didnt think it would work as well because it would be harder to properly aim where exactly the water would "run off to"
Question.
Does the water temprature matter? i.e. If you put regular water in there instead of ice water, would it be better because it would change temprature faster and thus evaporate faster? Or would it be better to drop some ice cubes in, because the cooler water can take away more heat?
ASE: Brakes
Old Sep 22, 2004 | 12:47 PM
  #29 (permalink)
Kyle K's Avatar
vw/audi
i did and yes they are. Name me one car that comes with a TT stock ? .. TT's are left over from when oils were mineral based and turbo technologies were not as they are today.. when you could actually cook the oil and seize the turbo. With most modern (post about 1990) cars.. and partial or full synthetic oils.. couples with tri action cooling (oil/water/air) .. heat disapates extremely quickly and the oils dont have the same issues tghey used to have.. just driving to park your car.. or checking the mail.. or even stopping to get out and look under the hood allows the temps to reduce enough ... couple that with most cars continue to circulate oil after you stop .. through either convenction .. or an electric motor .. it all adds up to TT's being a HUGE FUCKING WASTE OF MONEY AND A "LOOK AT ME I'M A RICER" end result
OY good post!
This still doesnt explain why in some cases (using S4 as example) the turbo's seized because the oil didnt properly cool down resuliting in a build up in the oil lines causing lack of oil going to turbo resulting in KABOOM!.. It might just be an Audi thing though. The problem was of course - small oil feed lines. Which is why I am, and choose to be.. a "ricer"
Old Sep 22, 2004 | 12:52 PM
  #30 (permalink)
Kyle K's Avatar
vw/audi
Originally posted by Kyle K
OY good post!
"Name one car that comes with a TT stock" .. I'll name TWO. Even though i'm sure there are more.
Audi TT
Porsche Turbo(Late models)
**Though they arent like a normal TT. Instead - only the oil pump runs for a few minutes after the car is shut down. Different method. Same purpose.
