what to do if oil pan nut striped
Old Jul 14, 2004 | 01:46 AM
CBER's Avatar
Default what to do if oil pan nut striped
i couldn't change my oil cause the nut is striped. is there a way to get it off so i can drain the oil. i don't have an impact wrench so
Old Jul 14, 2004 | 04:20 AM
moldyhands's Avatar
Porno Music Producer
take a phillips head screw driver. put the point against the bottom of the drain pan, and hit the end with a mallet. that should allow you to drain the oil.
you're on your own for plugging the hole again.
and thinks it's really funny when her nose goes bloody
'cause the blow is so yummy and it keeps her tummy empty
and makes her act more friendly
moldyhands's Avatar
seriously, try vice grips. someone else can chime in, would an easy-out work in this situation?
Old Jul 14, 2004 | 06:27 AM
iiibdsiil's Avatar
If it is the head, use a gator grip. It has gotten me out of a lot of situations. If it is the threads, work it out, then go to the auto parts store and pick up an oversized oil plug. They sell them all the time.
Too many Tire Kingdoms and Pep Boys putting the shit on with impacts.
Old Jul 14, 2004 | 12:38 PM
aaron1017's Avatar
is not Rotarded anymore!
Use some Locking Plyers! Those things are the shit!
LS1/T56 Heads Cam 1994 FD
Old Jul 15, 2004 | 06:42 AM
chi town brat's Avatar
! Ne shab'rud'ni !
gawd that is f*ing PATHETIC how weak are those workers
Old Jul 15, 2004 | 07:50 AM
Whaazup17's Avatar
if it is the threads you are going to need to tap and die it and clean the threads out.
