sunfire overheating
Old Jun 8, 2004 | 02:37 PM
accordfan's Avatar
I Miss Florida
Default sunfire overheating
my gf's 01 sunfire keeps running hot. on my honda accord the water pump has a weep hole that drips when its bad.does the sunfire have one too?i cant trace any water dripping when its idling, i think its only when its being driven?help please.
DOHC VTEC 5 lug 94 accord
legend calipers,h23 tranny
Old Jun 8, 2004 | 02:57 PM
0HP930's Avatar
Guest
If its not loosing water it could be a bad thermostat, clogged radiator or bad water pump impeller. If its loosing water but its not leaking it anywhere it could be blown headgasket or cracked head.
Old Jun 8, 2004 | 03:03 PM
markzeronine's Avatar
Mark G
when it happened to me it was the headgasket
Old Jun 8, 2004 | 03:04 PM
TheShow50h's Avatar
The little 5.0 that could
That's probably where all my coolant is going. Damn headgaskets.
-Vince
Old Jun 8, 2004 | 03:15 PM
0HP930's Avatar
Guest
The only water I have to be concerned about in my preferred car is in the window washer.
Old Jun 8, 2004 | 03:29 PM
TheShow50h's Avatar
Yea, lucky you
-Vince
Old Jun 8, 2004 | 03:32 PM
accordfan's Avatar
I Miss Florida
the car is a 2001, how could the headgasket be bad,ill check the oil for coolant, the seal around the water pump looks damp but it looks like the oil from the small valve cover gasket leak.
Old Jun 8, 2004 | 03:35 PM
TheShow50h's Avatar
I think if a valve cover gasket leaks and the waterpump gasket isn't sealing properly, a failing headgasket in a 2001 isn't too far fetched.
-Vince
Old Jun 8, 2004 | 03:40 PM
Illswyn's Avatar
New cars have problems too.
Old Jun 8, 2004 | 04:16 PM
accordfan's Avatar
I Miss Florida
ok i drove the car for 10 min and it got close to 200 degrees. theres no coolant in the oil. but i have no tools at my apt to take anything apart to see if where its leaking.theres a steady drip from underneath near the compressor bracket..if theres somone in the brandon area that could help after i get off of work tomorrow that could bring some tools that would be great. when i get paid i could pay you some money or buy you some beer.you can call me684-1953.thanks,,,,joe..
