Check Engine Light Trouble...NEED HELP FAST
Old Mar 28, 2004 | 12:27 PM
gabe's Avatar
clever individual
resetting the CEL is usually done with some type of interface software (laptop etc) but sometimes there are manual methods of doing it, like unplugging the battery for a bit. just because theres a CEL doesnt mean that there is a current problem, sometimes it just needs to be reset. you could probably go to a nissan shop and they would do it for you.
any time you open your MAF to the open air, you expose it to anything and everything floating around. theyre quite sensitive, so that couldve pissed something off.
if your car still runs fine, id have to think that the MAF isnt broken and it doesnt need to be replaced (if it was broken the car would run horribly) and replacing a MAF isnt quite the cheapest thing.
-gabe
Old Mar 28, 2004 | 12:31 PM
gabe's Avatar
clever individual
im sure you can find a tutorial on a nissan-specific web site. a lot of times it requires gentle handling, soaking in rubbing alcohol, and some other procedures.
-gabe
Old Mar 28, 2004 | 01:10 PM
Country Boy's Avatar
can survive...
I clean mine with electronics cleaner from Radio Shack.
Old Mar 28, 2004 | 01:12 PM
TampaTSi's Avatar
go to autozone. they will read your OBD code for free. then look that code up on the internet to see what the probable cause is. if it is air related, you're probably good to go.
also, autozone will clear the code so you can see if it comes back or not
1998 Eclipse GST
Old Mar 28, 2004 | 02:15 PM
  #17 (permalink)
can survive...
Have you checked your oil... lol Some cars throw a SES light for low oil.
